Question about InFocus ScreenPlay 4800 Multimedia Projector
My InFocus for the classroom won't even turn on. Absolutely nothing is turning on even though it is all plugged in correctly.
  • Scott Frye
    Scott Frye Oct 11, 2010
    Has it been dropped recently?
    and, how old is it?...Has the lamp ever been changed?
    Thanks
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Either the power input board is bad,the fuse on the opwer supply/ballast is blown or the lamp door is not secure. This will have to be repaired by a tech if is either of the first two.
Posted on Oct 12, 2010
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Infocus in104 projetor problem: power off, temp red, lamp green
Most probably failure of the thermistor or thermal fuse that detects the temperature of the lamp housing - so the projector thinks it's hot even when it's cold. Unfortunately it will need a trip to an authorised service centre for repairs
Apr 04, 2014 | InFocus IN104 Projector
My VW golf TDi won't start since I changed my battery. It started fine for three days and now there is absolutely nothing there when I turn the key not even a click. Please help
1. Do all lights, accessories, central locking system etc in the car all operate normally.
2. Have you tested to see if the car starts when you try jump starting from another vehicle.
3. What warning lights were displaying on the vehicle a day or 2 before you had the problem.
4. Were you having the same starting problems with the old battery that you have just replaced.
Dec 27, 2012 | Cars & Trucks
Archos 70 won't turn on
I have the 8gig Archos 70, the whole thing froze as described in other posts. The solution is not for the feint of heart though. Mine would do absolutely nothing. So what the heck, I opened it up (nothing to lose at this point). Messed about a bit. Read that when it "Bricks" like this there is nothing that can be done. If it is Bricked, something locks it in the memory and function. As long as the battery is connected, it will remain that way no matter what.
Solution. Cut the black power wire from the battery (there are three long wires red white and black), leave for 20 minute, and solder the wire back together and heat shrink the joint. Reassemble, plug in power cord and it should reboot...
My archos is about 3-4 years old, and is mounted to the wall in my kitchen for use as an internet radio
Feb 28, 2012 | Archos 70 android tablet Notebook
Projector will not turn on
Is this machine newer? Is the lamp still good to go for a while or has it been burned alot the last year? If so, you might want to consider replacing the bulb. It is also a good idea to check power to the bulb socket to tell if there is a burn fuse or not. If lamp and fuse are good, then you may have a bad power supply.
Sep 03, 2009 | InFocus IN2104 Projector
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
I want to test my infocus lamp to know if it is burnt
Your lamp might be ok, but you power supply is dead. If your not seeing any led lights come on when the power cord is plugged in then your power supply is dead. I can fix this for you for less then it cost to send to infocus or to a repair shop. Ebay Id is Gtitubro
AIM - Gtitubro
Feb 12, 2009 | InFocus Lamp Projector Lamp for LP650,...
Infocus LP350 won't show signal, also panel buttons don't light up
Hi LuckyLindy
Next time this happens , just take out the main connection to the Mainboard and plug it back in.
Also remember to reset your lamp timer now that you have replaced the lamp !
Apr 24, 2008 | InFocus LP350 Multimedia Projector
InFocus ScreenPlay 4800 Multimedia Projector Logo
91 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
