Question about Vizio L32 32 in. LCD HDTV
Hi I have a l32hdtv10a that blows fuses on the power supply board.Is it the power board oanother board blowing the fuse? Or do I just install a higher amp fuse? Please help Tony
  • dbourg69 Oct 12, 2010
    My question still stands.
    If the power is connected to the power board and nothing else is connected and the fuse blows,is the problem the power supply board?
    Hello
    My power supply on my flat screen blows the fuse as soon as it is energized.I removed all out going loads from the power supply.Does that indicate that the power supply board needs to be replaced?
    Thanks Tony
  • Vizio Master
  • 11,800 Answers
Yes, if nothing is connected to the power board but the fuse still blows then the short (and a big one) is definitely in it - replace it with a new one, this one is dead as a dodo.
Posted on Oct 12, 2010
  • 10,515 Answers
NEVER EVER replace a fuse and think that the fuse will blow all by itself. The fuses are there to protect the set from catching on fire.In case there is a short inside the set. Now in some cases an intermittent short can work after you replace the fuse but if its burnt black or brownish, there is a short inside the set in one of the circuits. always use a 100 watt light bulb across a blown fuse if your not sure if there is a short. if there is, the light will absorb the short and glow bright. if there is no short the bulb will glow bright , then go down very dim. you could have a main power supply problem, such as shorted bridge rectifiers,shorted main b+ capacitor, Hot could be shorted, or the Vertical or audio output IC could be shorted.
If you have experience in repairing electronics, you could take a help from a service manual to find the values of different components to make sure that they are not out of order.You could buy the service manual from :-
http://www.servicemanuals.net/ServiceManual/VIZIO/l32hdtv10a/pos1/results.aspx
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 11, 2010
  • taran_2005
    taran_2005 Oct 12, 2010
    Thanks for your response!!
    Most of the times, it's not the case.
    Hope i helped you.
My Panasonic tc p55st wont power up.
Bad power supply circuit board. (very common).
Ps... Many have a fuse on the board, but then you need to know why it is blowing. If you use a bigger fuse you _will_ blow the board or something else.
With that said, you _could_ try replacing the fuse and/or even try a ''slow-blow'' fuse, just as long as it is _exactly_ the same amperage fuse.
May 18, 2015 | Panasonic Televison & Video
Ceramic fuse blows on power board
the power board is shorted and will need replacement. Yo can get the power supply board from www.tvrepairworld.com
Mar 16, 2013 | Sony BRAVIA KDL-40EX400 40" LCD TV
Crest audio ca4 blowing fuse
There is two possibillities to fuse blown off due to hi current flowing through fuse more than 3amp.because power supply componant like rectifying diode, filter capacitor or regulator ic ,regulator transistor shall be short circuited.
if you are tech......just remove amp. supply.from main power supply...try with another fuse........if fuse ok, fault is amp side, or if fuse blow off ...power side problem just....maximum fault comming on varistor ,diode, filter capacitor, .........
if you are not tech......... give to local authorised tech.......
Feb 04, 2018 | Crest Audio CA4 Amplifier Amplifier
No power or light, plus power supply keeps blowing fuse
you have a short most likely on the power supply but could be on the mainboard, inverter board, av/input board. The T-con board is fused and should blow its fuse before blowing the fuse on the power supply. I'm going with a faulty power supply, most likely a shorted Mosfet.
Sep 24, 2011 | Philips Magnavox 42MF521D/37 Television
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
Blown fuse on a ilpi-009 power supply
hi, i don't know the exact power board you speak of, most fuses for power supply protect ac inboard power, and backlights. if backlight inverters touch ground or ground out, this will blow fuse. otherwise, the fused circuit is used for main inboard power going to primary capacitor. take an automotive fuse holder and solder test leads long enough to work with, install 4 amp blade fuse and jumper/solder the circuit to the fuse on the board and power on the monitor. if all goes well, probably just power surge or outlet grounded. if blows fuse, check to board for obvious burns or blown capacitors. if not there, unplug backlights and power on, if still blows, check to make sure no direct conact with board and back of screen. just be thorough about looking carefully for shorts if there is one. and don't forget to replace the factory fuse on the board with the correct one after you finish repairing, don't leave that automotive fuse in. good luck.
May 10, 2010 | Emprex LM2201 22" LCD Monitor
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
Blowing fuses in power supply
One thing to check, would be the filter capacitator that is on the front circuit board. They are known to become shorted. The cap is fairly large, and may be mounted on the side of the circuit board that faces the front panel. Clip one lead, and apply power. If the fuse does not blow, then that is it. A second possible component, is the polarity protection diode, that is near the power jack, next to the fuse. If it is shorted, then the fuse will blow every time.
Aug 21, 2008 | Optics
Vizio L32 32 in. LCD HDTV Logo
102 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
