Question about Sharp AQUOS LC-26DV22U 26" LCD TV
How do i connect a dvd player with a 20 pin scart connection to the television what kind of cable do i need (20 pin scart cable to ? ) the television was bought in GOA INDIA
  • 449 Answers
You need a SCART to SVIDEO (or composite) + 2x RCA Audio cable, available from eBay or many AV providers. Sample: http://search.ebay.com/360338762039
You can wire your own. See clues at http://dbzt.freeforums.org/how-to-make-a-scart-cable-t342.html and http://pinouts.ru/VideoCables/scart_svhs_pinout.shtml
but you are better off buying a professionally made one.
Posted on Jan 25, 2011
How do I connect to tv there is nothing on the screen from the DVDs player
It depends on your connections for one thing. I did find this piece of information on the DVD player:
"One thing they do not state (in the manual) is that if you are playing it through your Scart socket to your TV. Your TV's Scart socket must be PAL60 compliant".
If they both have HDMI sockets I would get a HDMI cable and connect via that. You will also get a better picture than a scart.
If you are using a scart the connector can also become faulty either inside or a faulty pin so check that too.
Dec 14, 2014 | Alba DVD-108 DVD Player
Can you connect anothers dvd player to it
you will need to use the RCA inputs at the back of the TV (yellow red and white plugs), if the DVD player only has a SCART connector you will need to get a scart to RCA cable.
Apr 08, 2014 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
I have a ESA 427E TV and no remote. I have a Philips dvd player. How do I get it to work with this tv.
Hi there. Connect the player by means of a SCART cable.
When you activate the DVD, the TV recognises this and goes automatically into AV mode. About the scart cable: take a fully wired type. Then pin 8 is at least connected. This status pin makes the TV switch to AV mode. (toggles between 0 and 12V)
In some cases, it's only possible to connect the signals by means of RCA connectors. (red,black, yellow). Then it's more complicated.
You have to use the local "channel" buttons on your TV. Press the (-) button a number of times until you reach channels below 1. That's were AV inputs are active. Good luck.
Feb 15, 2014 | ESA ET427E 27" TV
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
New toshiba tv connect to sky plus box and perfect picture but no sound
The first thing to do is check the connections between the Sky box and the TV. If you are using a SCART cable, it's possible that one of the pins in the SCART plugs has bent or become detached from the wire inside. If you have another SCART cable from a VCR or DVD player, try switching them over.
If this doesn't work, or if you are using another connection method between the Sky box and the TV, please post back and I will try to assist you further.
Regards,
BElectric
Nov 29, 2010 | Toshiba Televison & Video
I need help connecting tv to DVD player VCR and satellite box
Connect as following
1. Set top box - RF cable from STB to antenna socket on TV.
2. DVD player output to Video1 on TV
3. VCR output to Video2 on TV.
May be you can route VCR through the DVD player or viceversa. That you can see and try on ground.
Sep 28, 2010 | Haier TN201AUV 20" TV
Can not connect dvd player to it
you have 3 way to connect with:scart cable,pin cable,or s-video cable...
Jun 13, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
Proscan PS8682P dvd player. It has been over a
so you have two problems: how to connect to (ex: tv),so for this. the cable box has a scart port? if so use a scart/rca adapter available on the market, use on VCR out (Cable Box) and select IN the adapter to IN/OUT switch. and connect to dvd player. The other Scart Port labeled TV connect to TV set with a scart cable. Now u can see tv, and switch automatic to dvd if DVD is on.
The Bad Disc error is a Laser DVD lens defective, needs to be replaced, send to repair.
Dec 28, 2009 | Proscan PS8682P
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Sharp AQUOS LC-26DV22U 26" LCD TV Logo
61 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
