Question about Boss Mt 2 Metal Zone Effects Pedal
Boss Mt 2 Metal Zone Effects Pedal Led light comes on but no sound passes thru pedal
4 Suggested Answers
  • 133 Answers
SOURCE: light indicator is on
Try changing the battery, if it doesn't help, some possibilities are:
- dirty contacts or a broken wire on the footswitch
- a broken wire from the distortion output to the output plug
- a broken wire elsewhere in the unit (e.g. potentiometers or rotary controllers)
- a bad input / output level or other potentiometer or rotary controller
- a burnt out component (a bit unlikely, but possible, and it could be anything)
- a bad connector contact inside the unit
- a bad pin solder contact on ANY of the components inside the unit (wires, connectors, switches, jack plugs, resistors,variable resistors, trimmers, diodes, capacitors, transistors, ICs, etc.)
Broken wires / badly soldered pins need to be resoldered, but if there is damage to any of the components, they wil probably need to be replaced.
I hope you can find out what it is.
regards
3rq8 (Triarcuate)
Posted on Aug 02, 2009
  • 4 Answers
SOURCE: There is a constant loud hum/buzz whenever I turn
First and foremost , check your signal chain. By that, i mean put the pedal aside, ...just unhook it and take it out of your signal path. Using the same cables , guitar , amp, other pedals - borrow a friends MT-2 if you can get one , and try THAT to see if THAT works , OR any other kind of distortion pedal. If another one works ok , it's YOUR MT-2. Boss pedals are pretty rugged , but sometimes the little actuator (on/off switch) underneath the treadle (where you push your foot down) will become faulty. That's a high-gain pedal - are you using a basic Strat or other single-coil pickup guitar? If so , are you playing close to any flourescent lights? SIngle coils are noisy around those lights. Will cause a hum / buzz if using a heavy dist. pedal. You can check that by moving around as you play.
Posted on Nov 02, 2009
  • 298 Answers
SOURCE: I just got a new Boss Metal Zone MT-2 pedal 3 days
Try the obvious stuff first.
  1. Check that it has a battery in it and it is installed the right way round.
  2. Only use top quality batteries (Duracell Ultra or equivalent) do not use re-chargeables as they don't achieve adequate voltage.
  3. If you are using a mains adapter try a battery instead as the adapter may be faulty (or vice versa)
  4. Some effects pedals will not switch on without a jack plug in either the input or output socket (or both)
  5. If none of that works it is probably faulty - take it back to the shop and ask them to replace it or prove it works
Posted on Jan 30, 2011
It works fine for about a few minutes and then the light is slowly getting pale and the sound slowly looses power until it doesn't give any sound at all. Tried a few different batteries, same thing.
Battery is not the problem.
It could be transistors, IC, elco etc. It must be checked.
This electronic parts, could be almost breakdown. At the beginning of the device is turned on, it work fine, but after a while it became hot, then the value is changed, then the circuit was not working.
Can also occur on the DC input, the diode and the elco (D006,C019,C40,C41). View image.
23095950-2ss5ycyvkoajtv035dpuezke-1-0.jpg See the full diagram here :
Boss MT 2 Metal Zone distortion pedal schematic
Jan 24, 2014 | Boss Mt 2 Metal Zone Effects Pedal
Whenever i push the the pedal down the distrotion comes on for 10 seconds and then turns off and the light doesnt turn on either help me!!!
If you are running on battery, replace the battery. The batteries tend to recover a bit and will operate the unit for a brief period
Mar 18, 2011 | Boss Mt 2 Metal Zone Effects Pedal
Check does not work does not turn red light metal zone boss
Check your power adapter or battery if you are using a battery.
Jan 29, 2011 | Boss Mt 2 Metal Zone Effects Pedal
How to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
Nov 24, 2009 | Boss Mt 2 Metal Zone Effects Pedal
There is a constant loud hum/buzz whenever I turn the pedal on. With my Boss Mt 2 Metal Zone effects pedal. It happens whether or not the power supply is plugged in. Ive tried switching cables and...
Nov 02, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Light indicator is on
regards
3rq8 (Triarcuate)
Jul 26, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Metal Pedal mutes my guitar.
Sell the pedal and get a digitech, or convert it into a looper pedal.
Apr 05, 2009 | Boss Mt 2 Metal Zone Effects Pedal
The Distortion Pedal has no effect on the sound.
i got d same problm. i fixed it myself.. check all the op amp ic's if they're all gud. if youre not sure, replace all 4 rc4558 ic's. in my case, i still felt a very small output signal from my pedal (equalizers, vol n gain ctrls r gud since they vary when i change the setting) so i suspected that one or 2 of my ic's were damaged. i only replace d last two op amps which my signal passes thru. i also had this problm with my marshall drive master. same diagnosis and solution. check your schematics
Dec 14, 2008 | Boss Mt 2 Metal Zone Effects Pedal
Boss Mt 2 Metal Zone Effects Pedal Logo
232 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Darial Jr Lasaria
Darial Jr Lasaria
Vito Vacirca Jr.
Are you a Boss Music Expert? Answer questions, earn points and help others
