Question about Hotpoint HSS25GFP Side by Side Refrigerator
The temperature in both the freezer and refrigerator sides is not cold. Ice cream is like syrup and there is frost on the back wall of the freezer. It is cold, but not cold enough. The door closes well and I have the temperature at 5 now, previously at 4 with no problems.
    Sergeant:
    Champion:
  • 351 Answers
Hi you have a defrost element problem Hotpoint and GE do burn out element . the element are in the back of freezer jim
Posted on Oct 12, 2010
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
Freezer is not working. Ice maker is working. Started noticing the past 2 weeks that ice cream is melting. Refrigerator is working but not keeping things really cold. The unit is only 3 years old.
ice mker will soon quit as when ice cream is soft the tempt is rising . look for frost build up in back wall of freezer . if so the heaters have failed ( very common ) . they will have to be replaced . there is a new style that replaces mose G E heaters . and they are much better .. mm
Jul 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi, I got no Ice in the freezer, and the Ice Cream is not hard
the higher the # the colder the frig should be . / if ice cream is not hard the freezer is not cold ennogh . so clean the coiles and ck the two fans . also look in back of freezer side for ice build up there should not be any frost on back wall . if so you've found the problem . which is a defros problem .. mm
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
First my refrigerator side stopped getting cold ,now my freezer isnt working the best , also theres frost in my freezer
you found frost in the freezer on the back wall . this caused no air flow through the coil. what has hapened is / the defrost system has failed . and the ref side gets to warm and next the ice cream will melt . look for bad heater or defrost terminator . and the defrost timer . . most compn problem .. mm
Jul 04, 2010 | Whirlpool ED2FHSS Side by Side...
My maytag refrig. is 3 years old. model #747908 HS520AS. freezer on bottom-refrig on top. the refrig part is not staying cold. have cleaned under frig and vaccumed back and underneath and it still is not...
All the cooling coils for this model are in the freezer section. There is a fan down there behind the back wall on the top. This fan directs air up to the fresh food section.
Check the temperature of the freezer you can do this by inspecting the ice cream, if the ice cream is soft you are above 5 degrees F. If you have a good cold freezer then the problem is with air flow, the evaporator fan that I spoke of could be bad).
If your freezer temperature is not as cold as it should be you may have a defrost problem, look for any signs of frost build up on the back wall of the freezer section, if you see frost you will most likely need to put in a new control.
If the freezer temperature is warmer than normal and you do not have frost you may have a sealed system leak, this will require a technician for sure.
Apr 18, 2010 | Maytag Refrigerators
It's not staying cold. ice cube are not frozen, ice cream melted, frost on inside freezer on back wall.
something is wrong with your condenser fan motor or your evaporator Or your defrost timer which controls what temperature you put in.try serviving it
Mar 05, 2010 | Refrigerators
I have a Frigidaire side-by-side refrigerator model FRS26ZNHB1. The blower is running continuously and the temperature in the freezer is not as cold as it should be. (Ice cream is soft - things are...
bad door seals, frosted up coils, low refrigerant, dirty/clogged condenser coils (under fridge), bad condenser fan. check the fan in the back. clean out the coils with a vacuum under the fridge. see if there is frost on the back wall of the freezer. if there is, you'll have to remove the back wall and defrost the coils with a hair dryer. check the door seals for leaks. replace if necessary. if all is well and still warm, you have a freon leak. call in the pros.
Nov 13, 2009 | Refrigerators
Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Jun 11, 2008 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
83 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
