Have a Hp Compaq 6230 that reads read disk error , So it wont boot up windows . So i went from a 40 gig hdd to a 320GB WD3200BEVE WD Scorpio Blue...... I cant seem to get my laptop to actually read off of this HD? what should i do if windows tries setup and then only wants to try setup again?? please help me
    Novelist:
  • 112 Answers
First, go into the BIOS setup to make sure the laptop is seeing the drive. Then you must partition the drive with a maximum size for the operating system partition at 137GB. The 6230 came in a couple of models but they are 32 bit processors and you must set up for 32 bit.
http://forums13.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1286837153800+28353475&threadId=1343862
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06a/321957-64295-89315-321838-f33-447349.html
Posted on Oct 11, 2010
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Jan 05, 2013 | HP Compaq dc7700 PC Desktop
I am trying to install a WD3200BEVE hard drive into a Dell Inspiron 6000 and it reads "Internal HDD Error" I received this hard drive from Dell after my previous hard drive WD600 went bad. Do I...
It's possible that the only problem is that the replacement disk-drive needs to be "initialized" for first-time usage. Or, it's possible that your Dell won't support your new _larger_ disk-drive.
Did they send you a disk-drive with _greater_ capacity than your old 60GB drive?
It's possible that they "upgraded" you, because they had no (small) 60GB disk-drives in inventory.
Take your Dell "System Restore" set of CD/DVD disks, and reinstall Windows.
The Windows Installer will "initialize" your disk-drive.
Dec 18, 2010 | Western Digital Scorpio WD600VE 60 GB Hard...
HP TC4400 hard drive ugrade problem
go to hp site and check is the model support 320gb hdd or not if not trun yr hdd in limited capisity
Feb 26, 2010 | Compaq tc4400 Tablet PC
Installed a 250GB WD Scorpio and it shows as a 130GB drive
make sure the laptop will handle a drive bigger than 130 gig. if not make two partitions when you set it up, bios wont see it but usually windows will. also, sometimes ive found that if i delete the partition a few times it eventually reads right. dont know why but have done it that way several times. you can also download a diskmanager program from thier website which makes an overlay if your bios wont support a 250.
Aug 23, 2009 | Western Digital Caviar WD2500BB 250 GB...
Formatting a Compaq nc8430 laptop
you need a compaq boot disk
ferkin compaqs are a pain in the O
try pulling the drive and inserting it into a portable enclosure than format it you will probably find there is 2 partions on the drive
usualy the first is the small 1 and it has only enough space the boot then it kicks to the second 1
if you use a portable enclosure and use the manage command you can see the partitions and you can format it as 1 huge drive rather than 2 smaller ones
Jul 07, 2009 | HP Compaq nc8430 Notebook
Additional Hard Drive
The Motherboard will be able to handle it and XP will read the hardrive i have used a 500 gig hard drive in my old computer before it should work just fine
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
WD Scorpio Black 320GB SATA drive
Halarious, I had the same problem yet I used norton ghost. At least you still show 160 gb. Mine went all the way to 60 gb. Here is what I had to do to reclaim the lost. I downloaded something called "Magic Boot Disk" It gave me the whole 320 back yet have not found good cloning software yet. Magic Boot Disc is freeware avaliable at http://hddguru.com/content/en/software/2006.02.10-Magic-Boot-Disk/ Good luck cloning
Feb 21, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Presario Media Center new SATA 320GB WD
Check to make sure you used a SATA hdd & not a SATA II hdd for your replacement. Usually these are not backwards compatible. Hope this helps.
Jan 10, 2009 | Compaq Computers & Internet
1781 Disk 1failure
Hi I have the same problem - when I turn on my compaq nc 6230 it says "1781 Disk 1failure ", I click enter button and it's starts to boot windows xp and works good without any poblems. I took the HDD out and install into different nc6230 and it works good and no any erro "1781 Disk 1 failure" at all - so it's NOT an HDD problem ! Can somebody help to troubleshoot ! Thanks.
May 17, 2008 | HP Compaq nx6110 PC Laptop
Compaq armada e500 850mhz p3 laptop
I'd like you to get into your bios. At the main bios window make sure your bios is seeing the hard drive correctly (model number). Also check that your cdrom is listed. While in the Bios go to boot & correct the boot order. 1st should be cdrom, 2nd should be your new Hitachi.
You mentioned you connected it to a PC. Than you installed WinXP & everything went fine. Disk read error means your laptop does not like the FAT. When you bought the Hitachi did you get a disk utility? If not download it from the link provided here & test your drive. Use the disk utility to set up your new drive & format
it with the utility. Try again to boot to your cdrom & install WinXP. If your XP does not include SP1 or SP2 your drive may show a smaller size.
http://www.hitachigst.com/hdd/support/download.htm
Good luck, I hope the disk utility fixs the problem.
http://www.hitachigst.com/tech/techlib.nsf/techdocs/50C8DBC2A315A4C786256F400065B756/$file/7K100_SATA_FINAL_DS.pdf (Info)
Feb 23, 2008 | Dell Inspiron B130 Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
