Question about JVC AL A158BK Turntable
I have a QL-F300 and am trying to connect it to a Yamaha RX-V470, but it won't play. Help?
Yamaha rx-v361 turns on and off
If it turns off while playing, it might be tripping a overload circuit and resetting. Try it will just a couple low watt speakers connected and see
Sep 05, 2014 | Yamaha Stereo Am Fm Receiver Tuner...
Yamaha rx v470
Can you hear sound via the headphone socket? If you cannot then the main amp has failed. If you can hear the sound, then the headphone socket could be faulty.
May 28, 2013 | Audio Players & Recorders
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
Yamaha Receiver RX-V3800 Rear Left surround click sound
It's possible it is some sort of interference pickup, but another possible I've come across a number of times on Yamahas is poor earth connections via the back panel.
All the circuit boards have earth connections on them and the screws holding them to the back panel form an earth bonding connection. Tighten all the screws on the back to eliminate this possibility. Costs nothing to try and may just solve it.
Jul 19, 2010 | Yamaha RX-V3800 Receiver
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Nov 26, 2009 | Yamaha RX-V863 Receiver
My Yamaha RX-V470 Kicks off after a couple of SEC.
Two possible problems , bad memory back up cap or weak voltage regulator.
Jul 10, 2009 | Yamaha RX-V995 Receiver
Getting to work your pc music files through the usb connection
how should i connect my yamaha rx-v2700 to my desktop pc and which software i should install on my pc and where to download this software
Feb 12, 2008 | Yamaha RX-V2700 Receiver
RX-V661 Receiver
your receiver has zone 2 output which is operated independently of the main reciever. so you can have a dvd playing inthe main reciever and the tuner playing over the intercom. read about it in your manual page 89. in will hook up to 2 RCA jacks in the back Zone 2 out.
Dec 29, 2007 | Yamaha RX-V661 Receiver
JVC AL A158BK Turntable Logo
101 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
