Question about RCA R52WH76 Television
The screen is showing multiple colors and is not taking up the whole screen. There are three color lines running across the top of the tv and the screen looks curved in.
    Genius:
  • 1,030 Answers
This sounds like what is called convergence issues. Convergence problems is common on prrojection tvs specially this model. First question is in the customer setup menu do you have the convergence option. if you do not you need to read the artlce called fl231 fuse problem it could be the problem and its the first place i look at when i get this at the shop. it located in the tips and trick sections of this website.http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in
Posted on Oct 13, 2010
TV HAS A COLOR LINE WHEN IS ON IN THE MIDDLE OF SCREEN
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Mar 10, 2013 | Sanyo DP50747 50 in. Plasma TV
I have a multi colored line running across my screen and I can't get my digital antenna channels? Any ideas? Tv is only about a year old and I have unplugged it for an hour to reset it but it didn't w
Hi it sounds like you have multiple problems with your tv. First you said that there were no digital channels. The tv has a bad signal board. The second problem is the colored line running across the screen. That could be two things either the screen itself is bad or your t-con board is bad. The t-con board would be the cheapest of the two to try. You can get parts from www.interliquidparts.com
Dec 13, 2011 | Sylvania LC260SS8 26 in. LCD Television
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
Color on the screen
Convergence is dead.Know how to solders?Replaced 2 convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Feb 02, 2010 | RCA D52W135D 52 in. TV/DVD Combo
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA R52WH76 Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
