Question about Everex StepNote NC1500 Notebook
Problem playing games
Well i know the problems on my computer cause i've installed 2 games on my laptop and the same thing happens what happens is it only shows me a section of the game im playing and the other parts on it are just black and you cant see anything and i don't know what to do or how to fix it, it never ust to do this
  • 868 Answers
Your graphics driver/memory are in need of a upgrade
Posted on May 31, 2008
Wierd Colors after Playing Games ?
Dear you need to check 2 things.
1. Replace the Ram (replace the ram and then check if it gives error or not)
2. Update your Windows / graphic drivers to the latest one.. you also need to update Direct x .
Goodluck
Regards-Bilal
May 29, 2014 | Acer Aspire 3000 Notebook
Age of Empires 3: Warchiefs installation error.
Install it in order:
1. The main game
2. Warchiefs
3. Asian Dynasties
Then it should work... I had the same problem.
Oct 14, 2012 | Microsoft Age of Empires III - The War...
Sims 2 bon voyage stops installing at 57%?
um-mm...some disc are really thin and have trouble reading the disc because it is spinning far to fast. This usually happens far to fast. You could also get a cleaning disc, that they usually have for DVD player, I don't know if they have one for the computer or not, but it would be great to look into. Also, one new thing that people aren't looking, because this happened to my DVD player, you see, my DVD player kept saying wrong disc, and it was because a battery had a whole in it, and the corrosion of the battery melted and destroyed the Lazar, as well as flowing into the jack. so I had to get rid of it before fixing it. Now, it probably can't copy the file, because your computer needs its hard drive updated, as well as the AGA Graphic memory, I had trouble with a game one because it didn't have enough graphic color for 3d flash games. So check for that. Take care and good luck.
Sep 18, 2012 | Electronic Arts The Sims 2: Bon Voyage
My computer just shuts down on its own after about 20-30 minutes of playing certain games. this hasnt happened in the past and is frequently getting worse and worse
Make sure your hardware isnt getting too hot.
I've your CPU reaches 90 degrees, its gonna shutdown your computer, in order to protect itself from dying.
Try reading your hardware degrees using SpeedFan.
http://www.almico.com/sfdownload.php
When done, send me some screenshots.
djskywalker@live.nl
Jun 20, 2011 | Computers & Internet
I know nightmare ned wont work with windows 7 which is what i have so i installed it on my windows virtual pc in xp mode and the install went fine. But when i try to play it nothing happens. I click on the...
Depending on how old this game is, ( like made before 2002) It is out of date to current windows systems, you would need something like windows 2000 or windows 98 for the game to work
Good Luck I hope this helps :D
Jun 13, 2011 | Disney Interactive Nightmare Ned for...
Error says: UNHANDLED EXCEPTION: ACCESS_VIOLATION (c0000005). What does it mean?
yea i have the same problem
i think its because i full-installed the game, cause this bug happens only when cinematics gotta play.
so yeah ill try to install multiplayer version maybe tonight and tell you more slow things down alot when playing on bnet, doing stuff fast tends to cause crashes and temp bans
Jan 24, 2010 | Blizzard Entertainment Diablo 2 for...
When i play sims 2 it always hang then my pc will shut down automatically. the spec of the games are compatible to my loptop what will i do?
There is a problem of overheating. Maybe the specs are almost exactly the same as the game requirements. So the PC still has to work hard. This causes overheating, which should not happen if it is even perfectly compatible.
So, this means that something is causing the computer to overheat. Firstly, shut down any open background programs. Also, see that the laptop vents are not blocked by any thing around. Remember to dust the heatsinks, fans and the casing. Also, the keyboard and main vents. If you can, vacuum it all and open up the casing to be sure that all the gunk is out.
Jan 30, 2009 | Toshiba Satellite A75-S231 Notebook
Potential Heat Damage?
alot of the games require that a certain video card be used for otimal graphics. your laptops computer could very well have a card that is not up to the challenge of running those games. if you can watch movies and play music and all that other stuff it might just be that. the card you have in your laptop is just not up for the task. my personal opinion and on i am in the process of doing is building a gaming computer. use the laptop for work related things or school related things and the desktop for gaming.
Sep 23, 2008 | HP Pavilion dv6000z Notebook
Everex StepNote NC1500 Notebook Logo
167 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
