Question about Sonance Cinema 5150 5-Channel Amplifier
I have an onkyo reciever, 2 sonance 5150 (5 channels each) amps. i need to know the name of the piece of equipment needed to split my 2 channels out from reciever into 10 channels to go into the amps. y splitters wont have any signal left by the time they get to 10.
    Genius:
  • 1,175 Answers
You need an audio distribution amp ( line level)
Posted on Oct 12, 2010
I have 2 Sonance Sonamp 260's and I want to bridge them to run two different channels. Although I am not sure on how to do this. I am using my Carver HR-742 and I will be powering 2 Infinity SM-155's. I...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/search?q=Sonance+Sonamp+260
It's not bridgeable according to the manual.
Who specs an amp at 3 ohms anyway? Your Carver might be just as effectively powerful.
May 01, 2011 | Sonance Sonamp 260 MKII 2-Channel...
Sonance ASAP1 2 channel amp/switcher keeps blowing fuses. I'm using the 1A-250V slow burn fuses like it states on the rear panel. I plug it in and it instantly blows the fuse.
If fuzes burn out at connection to computer , that necessary to check:
1 Presence of the earth between body PC and amplifier.
2 Levels of the signal at the input amplifier must be minimum.
Jan 03, 2011 | Sonance ASAP1 2-Channel Amplifier
On my sonamp 260 when i hook up my cd or tape player to the amp i get no sound from the speakers out but, i get a little sound from the line out
I reckon the line out is for connecting the pre-amp section to a powered amp. Which is why you are hearing the weak signal. In which case it's clear to me that for some reason the power amp section in your Sonance is dead! Since it's a stereo amp it's something that has killed both channels. Like a power-amp IC such as the picture I'm posting below. Or something else that is accross both channels, but not the pre-amp section.
Aug 27, 2010 | Sonance Sonamp 260 MKII 2-Channel...
7.1 preamp output
called onkyo and kenwood they explained in detail how to hook up.
Jan 06, 2010 | Onkyo M-282 2-Channel Amplifier
Purchased 2 used sonance sonamp 260 for homewide speaker system (12 pair).line out from receiver into first amp powering first 8 pair.line out from first amp into second amp powers remaining 4pair.only...
I am assuming you are using the standard sonamp 260 not a 260x3
and that when you say you are getting sound on only 1 pair that means only on 1 side (left or right channel only?)
Are using a speaker selector box? you must to regulate the resistance (ohms)
if so first unhook all but on pair of speakers and see if both channels are working.
if they do your problem is in the speaker selector not the amp if no then check to see what the amp level is set to. These are the two small holes on the front right of amp make sure they are set about equal at around half way up.
If that doesn't work flip the RCA cables coming to the amp perhaps you have a bad cable if that doesn't work make sure your receiver (source) is outputing a stereo signal to begin with.
lastly 8 sets of speakers off 1 amp? that's pushing it.even with a high quality Niles or speakercraft selector that controls the resistance going to an amp I wouldn't go past 5 sets.
The right way to do it would be to use 260x3 or a sonance or speakercraft 12 channel amp.
Nov 04, 2009 | Sonance Sonamp 260 MKII 2-Channel...
I got this amp from a garage sale and it has no manuals. Trying to figure out how to hook it up
Here you go bro:
http://docs.google.com/gview?a=v&q=cache:6hHh18UZsloJ:www.sonance.com/files/downloads/file/Cinema260AmpManual_Revised.pdf+Sonance+Sonamp+260+pdf+manual&hl=en&gl=us&pid=bl&srcid=ADGEESjDo20tG_6vpCpSsnzX7v0dH6vTAvGsy4cMblzyYH0iaIJpAyt0OVecrJRaDVNsFIvVF9aI0ZdN69nP6nXyQ-N6KQtdBNrtL-j6bD8yzupS9iTVdcKzCraFnavgFGNXF8SjPrXb&sig=AFQjCNFtaCgbZFC-dhO6QHrqGZf3BoqfGQ
Nov 01, 2009 | Sonance Sonamp 260 MKII 2-Channel...
Input block
dnt3,
Speaker terminal block comes in various sizes and shape. Choose the one that suits your unit best. Some have 2 screws or 4 to mount. You'll need soldering iron to solder the terminal from the inside of the unit.
Good Luck.
Apr 27, 2008 | Sonance ASAP1 2-Channel Amplifier
About converting from 110 volt to 220 volt Sonance Cinema 5150
Yes no problem all you need is a transfromer that converts 230volts AC to 110 volts AC.
Have a look in your yellow pages to find a Transfromer company
located in your vincinity.
You will need to visit him with the wattage of your amplifier and order a step down transfromer. (The wattage is found on the small plate on the rear of the amplifier. Sometimes its written as KVA?.
Please ensure that the plug on the amplifier is changed to specially fit the 110v output of the transformer this is a must as people plug the wrong plug into the wrong socket and burn out the amplifiers.
Cheers YUBEUT.
Apr 19, 2008 | Sonance Cinema 5150 5-Channel Amplifier
Sonance Cinema 5150 5-Channel Amplifier Logo
133 people viewed this question
Top Sonance Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ASTEREY ELECTRONIC...
Level 1 Expert
Are you a Sonance Audio Player and Recorder Expert? Answer questions, earn points and help others
