Question about Biozone Travel Aire 250T Air Purifier
The blue lite fades to black after awhile after powering it up
    Problem Solver:
  • 8 Answers
It sounds like the lamp and maybe the fuse has gone bad and might need replacing. Here are some Biozone lamps and fuses http://www.air-purifier.org/orderform.html
Posted on Oct 19, 2010
The power head on my ocean blue vacuum will not work
Broken wire in hose, connecting power head to the vacuum?
Aug 26, 2012 | Ocean Blue Water Products Vacuum With Air...
The blue light of my EcoQuest Fresh Air Purifier flashes
The UV light is a Flourescent like bulb. It has a starter. The starter and bulb can be bought on Ebay for about $20. It is easy to replace.
Mar 31, 2010 | Ecoquest Fresh Air Air Purifier
A resistor on the bottom of the machine is blue w/ one black stripe broke off at one end. it is in a circle listed F30. What is that, is it a resistor. known of my lights work, and the machine works when...
Normally the "f" signifies that it is a fuse, but if its a blue can with a black strip down the side, its a capacitor. You can remove it and take it to an electronics store and get a new one of the same size. Just remember which side that the black strip came from because that is the ground side, and must be soldered back in the same way. I don't see the reference number that you are speaking of, so I can't tell you which one to get.
Mar 18, 2010 | Ecoquest Breeze AT Living Air Purifier
Press power, buttons light up and thats it
Try pressing the clean cell now button & check pre filter button at the same time hold buttons down at the same time for about 5 seconds with the air cleaner turned of and blue screen lit
Jan 30, 2010 | Kenmore AC2044-1 Air Purifier
Ionic Breeze - Press Blue - Press Geen button
The blue means the germicidal lamp is operating. Re: green light - Normal operation at all power levels involves a pre-programmed cycle of altering high and low air movement. Press the the green to override the regular power control setting and run the unit at maximum power for five minutes. Your previously selected power level will resume after the five minutes has elapsed.
Dec 11, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Can't take back grill off.
Pull the blue tab toward the black grille and simultaneously slide the grill upward. Should fall off easily. Hope this helps.
Jan 26, 2008 | Sharper Image (SI871 GP) Air Purifier
DOESN'T RUN ANYMORE
Check the capacitors. There are two to look for, one on the motor, the other on the PC controller board.
STEP ONE: Unplug the unit and support it on a table.
STEP TWO: remove the controller board from the exhaust side of the unit by unscrewing the screws holding the cover to the unit. Unplug the motor wire harness by pressing down on the white retaining clip. They go only one way, but it doesn’t hurt to note which is which.
STEP THREE: Unbolt the ground wire from the face plate and the whole board should come out. Unscrew the four screws holding the PC board. Look for a little foam pad that will drop out. Remember where to replace it. Screws and capacitor may have blue locktite on them.
STEP FOUR: Find the capacitor. It’s the part that looks like a tootsie roll, black with two wires coming out one side. It’s between the CPU chip and the big red square block. If it looks bloated, burnt or melted, you found the problem. Replace it with a 1000 microfarad (1000 uf/ 10 volt) ten volt capacitor with a radial lead. About $5 for the part at most electronic parts stores. Careful desoldering the old capacitor to avoid damaging the PC board. WATCH THE POLARITY. There is a negative and positive side. The negative side has a chevron (<) mark and is marked on the PC board. On mine the negative side was nearest the black micro chip and the positive side was towards the red JEFU MPE part. Use a little bolt-tite on the screws of the PC board and some on the capacitor on the PC board to limit vibration. Reinstall the board, plug it in and give it a whirl.
If no joy, STEP FIVE: Find the motor start capacitor. It is bolted near the motor, black about 1x 2 x 4 and has two red wires coming out of it. Take a battery operated resistance meter on a setting of R x 100 or higher. Charge the capacitor by connection one lead of the tester to one red wire and the other lead to the second red wire. You may have to strip the wire to make contact. Next reverse the leads and you should see the needle jump. Do it a third time incase the first try was discharging. If no needle jumping, replace capacitor. Couldn’t find this locally. May have to by directly from JET Tools. L
Recommend you hard crimp wire splices if cutting off the motor capacitor. .  You can check the windings on the motor too. Check for continuity between the white-yellow-blue-black wires of the motor harness. Any combination should work. If not, motor shot, time for some bigger bucks nrepair.
Hope this helps.
Jan 06, 2008 | Jet AFS-1000B Air Purifier
Dead
check power outlet / test the Blue air power cable w/tester continuity , switch on and off, tester move forward and reverse meter means good plug/ if does not move the fuse of the unit is open.need to replace.
Dec 28, 2007 | Blueair Blue Air 402 Smokestop Particle...
Biozone Travel Aire 250T Air Purifier Logo
124 people viewed this question
Top Biozone Air Purifiers Experts
Are you a Biozone Air Purifier Expert? Answer questions, earn points and help others
