Question about Fluke Networks DSP 4000 Network Testing Device
When I turn on my Fluke DSP 4000 cable analyzer I see a message that reads "Internal Fault Detected 208." What does that indicate?
I keep getting wrong cables message when I try to set reference with my Fluke Omniscanner. I can do a wire map but the last pairs show shorts. Could the cables be defective?
They might be defective but if they are new and originaly supplied from Fluke the chance is minimal, but it is possible. Try with another set of the cables.
Sep 14, 2009 | Fluke Networks 3 ft. Testing device...
Clicking with no Sound
The TV is on protect mode. This happens when an internal fault is detected. When a fault is detected the protection circuit prevents the TV from starting , the clicking sound is the protection switch that keeps turning off the TV.
Sometimes protection is triggered by an incorrect voltage, or electrostatic charges accumulating on the TV PSU capacitors. In that case the problem is temporary, and will disappear leaving tv unplugged for some times. More often, when tv goes on protect there is an internal fault that must be fixed.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jul 12, 2009 | Vizio GV46L 46 in. LCD Television
Wont turn on hear a faint click sound
The faint click sound is the protection circuit that keeps turning off the TV. This happens when an internal fault is detected. Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected. If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition. The flashing light indicates a diagnostic state called protection. When the TV goes on protection there are only two possible reasons. 1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit. 2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light. If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes. If you are in situation 2 , then there is an internal fault. Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board. Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable. If under warranty contact the manufacturer ringing the number on the user manual If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 05, 2009 | RCA P52812BL 52" Rear Projection...
Tv Turn sound on, No Picture, turns itself off within seconds
The TV is trying to go on protect mode because an internal fault had been detected. For that reson the protection circuit keeps turning off TV continuously.
May 23, 2009 | Sony KLV-30HR3 30 in. LCD Television
Tv would not turn on and it makes a clicking sound constinuously.
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 10, 2009 | Toshiba 27A32 27" TV
My sceptre monitor S1902D won't turn on just stopped
If the monitor has no power at all then you have a dead power board, or a broken power cord, test also a different wall AC outlet.
If instead there is a flashing led on front of the monitor, that indicates a fault condition.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Mar 06, 2009 | Sceptre S1902D 19" LCD Monitor
Samsung crt monitor
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
Common faults that can occurr are a blown capacitor on power board, faulty convergence, fault on alignment circuits, flyback problem , or a fault on Digital board.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Jul 12, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
Turned off by itself, blinking red led at front
The clicking sound is the internal protection switch that kicked in because a fault had been detected.
First ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Jun 28, 2008 | Toshiba 42HP95 Television
Tv want turn on makes a clicking sound for about 3 sec like its trying to turn on but dont
Feb 11, 2008 | GE 31GT740 31" TV
Fluke Networks DSP 4000 Network Testing Device Logo
95 people viewed this question
Top Fluke Networks Computers & Internet Experts
David Payne
David Payne
Are you a Fluke Networks Computer and Internet Expert? Answer questions, earn points and help others
