Question about Ryobi Garden
I have a Ryobi Ground Force 6500 grinder that I need an Attachment catalogue for OR a LINISHER that fits said machine
  • 12 Answers
SOURCE: the pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Posted on Mar 16, 2009
protek480
  • 1714 Answers
SOURCE: Ryobi Bench Grinder with Linisher tracking difficulty.
It sounds like the pulley is not adjusted correctly. This is causing the belt to move on you. Carefully inspect and adjust the pulley so it is square and flat. Use a straight edge.
Posted on Jun 26, 2009
SOURCE: Black Residue on meat using Kitchenaid meat grinder attachment
the guy that said that the meat produces this is full of it since the black reside is the blade friction against the round metal piece with the holes, i had black fine powder all over my mixer without any meat
Posted on Jul 19, 2009
bbreton
  • 437 Answers
SOURCE: I have a Ryobi RLT 30CESA with the strimmer
I would not put a brushcutter blade on this unit. The curved shaft quik disconnect may not hold up to the shock torque created by the brushblade. It may damage the drive shaft since it is a curved shaft quik disconnect model. You may have to purchase a straight shaft trimmer to get that job done.
Posted on Oct 03, 2009
Lady Spark
  • 51 Answers
SOURCE: When using the grinder attachment it appears that
The grinder part is driven by a shaft from the motor, and not only held in place but caused to turn by a 'shear pin' passing through the grinder bit and the motor shaft. The broken pieces of the shear pin need to be removed from the grinder part and the motor shaft, and a new one inserted. A common 'roll pin' of the correct diameter should do the trick.
Posted on Feb 05, 2010
I have a Ryobi bench grinder and the grinding belt keeps slipping to one side have tightened to maximum and the belt says its for a Ryobi
it is slipping to one side because the pulley on the end is not aligned correctly
on the adjuster arm that holds the front pulley there is a lever or knob that you use to adjust alignment ( instructions in user manual) find that adjustment and slowly move it while the belt is running
you will see the belt running position change to you get it properly aligned
each belt regardless of ryobi or generic will need adjustment after fitting
Nov 27, 2016 | Bench Grinders
Kitchenaid grinder attachment
If the grinder is turning and not stalling it sounds like an assembly problem.
Jul 21, 2016 | KitchenAid Food Grinder Attachment
Wher can i get a output shaft for a ryobi EAG95100angle grinder 900w
go google and type in--- parts for ryobi 4 " angle grinder model eag 95
I recently spent may hours searching for parts for ryobi angle grinder 4" that is close to 45 years old and saw plenty of sites for ryobi and others that carried listings for many ryobi grinders
I suspect that you will be lucky as you have a model where as I didn't have that luxury
Jul 08, 2016 | Ryobi Saws
How do I get the grinding wheel off my Ryobi grinder It seems to need some sort allen key
There is a key that should of come with your grinder. It has two pins on one end and they are inserted into the steel center piece that holds the disc on. You then press a button that is ether on the opposite side or side of the head unit. That button locks the wheel as you turn the key handle anti clockwise to loosen. It's reversed to fit the new disc, these handles can be purchased from a hardware store and are cheap.
Feb 08, 2015 | Ryobi Saws
No coffeer comes out of the coffee spouts, maybe the steel filters are dirty, how can I cean them?
Before the instructions on how to clean the filters, Check the grinder to make sure is set properly.
It might be set too fine
Cleaning the brew unit filters
Wipe away any coffee residues from the steel filter in the funnel of the
brew unit with a sponge.
The chrome filter to the left of the funnel can be removed for thorough
cleaning. Check and clean the chrome filter regularly.
^ Remove the brew unit.
^ Fit the enclosed allen wrench (that you got with your machine) to the
connection point (see illustration in your manual) in the brew unit. Turn it
counterclockwise while supporting the chrome filter from below.
^ Remove the chrome filter with the screw.
^ Clean the filter with hot water and dry.
^ Return the chrome filter to the brew unit and secure it by turning the allen
wrench clockwise. Press slightly against the filter to allow threading.
Jan 18, 2011 | Miele Coffee System
Need brushes for Hg710 Grinder.Where can I find it near Centurion
Some local hardware stores have generic carbon brushes that fit a few power tools bring old ones to the store. The internet will tell you the nearest service center as well as help download a parts list.
Jan 18, 2011 | Ryobi 4 1/2" Barrel Grip Angle Grinder
I cannot grind cranberries through the grinder attachment for a Kitchenaid stand mixer. The grinder is turning but I have to use every ounce of strength to push the berries down the chute and I never had...
Hello, Please check your grinder's output end and verify that it is assembled properly and using the correct grate as it seems that your grinder is all jammed up at that end and will cause the input area to back up so you have to push harder to force it to work correctly. Good Luck! -Rich
Nov 24, 2010 | KitchenAid FGA Food Grinder attachment for...
What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
Jul 19, 2009 | Kenwood KM800 Major Classic Stand Mixer
Jun 25, 2009 | Grinders
Garden Logo
23 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
