Question about Motorola MT1000 Compatible 2 Way Radio Battery Eliminator
Codeplug locks up during progamming. Seems to read OK, but takes several tries
I have 2 that have the same issue. 88 shows on windows. Sometimes can read the radio, but can't pgrm
When I've tried, it almost gets thru the program dump then quits.
Both radios are 5-watt, 99 ch.
Software version is latest one avail for radio., R.03.02.01 if memory serves correctly.
Freq prgm for both are within the bandsplits
S/N 751ASW0889, and 751APL0736
document.getElementById("MsgContainer").innerHTML='\x0d\x0a\x0d\x0a\x3cmeta http-equiv\x3dContent-Type content\x3d\x22text\x2fhtml\x3b charset\x3dunicode\x22\x3e\x0d\x0a\x3cmeta name\x3dGenerator content\x3d\x22Microsoft SafeHTML\x22\x3e\x0d\x0a\x3cstyle\x3e\x0d\x0a.ExternalClass .EC_hmmessage P\x0d\x0a\x7bpadding\x3a0px\x3b\x7d\x0d\x0a.ExternalClass body.EC_hmmessage\x0d\x0a\x7bfont-size\x3a10pt\x3bfont-family\x3aTahoma\x3b\x7d\x0d\x0a\x3c\x2fstyle\x3e\x0d\x0a\x0d\x0a\x0d\x0aI have 2 that have the same issue. 88 shows on windows. Sometimes can read the radio, but can\x27t pgrm\x3cbr\x3e\x0d\x0aWhen I\x27ve tried, it almost gets thru the program dump then quits.\x3cbr\x3e\x0d\x0a\u00a0\x3cbr\x3e\x0d\x0aBoth radios are 5-watt, 99 ch.\x3cbr\x3e\x0d\x0a\u00a0\x3cbr\x3e\x0d\x0aSoftware version is latest one avail for radio., R.03.02.01 if memory serves correctly. \x3cbr\x3e\x0d\x0aFreq prgm for both are within the bandsplits\x3cbr\x3e\x0d\x0a\u00a0\x3cbr\x3e\x0d\x0aS\x2fN 751ASW0890, and 751ALP0736\x3cbr\x3e\x0d\x0a'; document.getElementById("MsgContainer").innerHTML='\x0d\x0a\x0d\x0a\x3cmeta http-equiv\x3dContent-Type content\x3d\x22text\x2fhtml\x3b charset\x3dunicode\x22\x3e\x0d\x0a\x3cmeta name\x3dGenerator content\x3d\x22Microsoft SafeHTML\x22\x3e\x0d\x0a\x3cstyle\x3e\x0d\x0a.ExternalClass .EC_hmmessage P\x0d\x0a\x7bpadding\x3a0px\x3b\x7d\x0d\x0a.ExternalClass body.EC_hmmessage\x0d\x0a\x7bfont-size\x3a10pt\x3bfont-family\x3aTahoma\x3b\x7d\x0d\x0a\x3c\x2fstyle\x3e\x0d\x0a\x0d\x0a\x0d\x0aI have 2 that have the same issue. 88 shows on windows. Sometimes can read the radio, but can\x27t pgrm\x3cbr\x3e\x0d\x0aWhen I\x27ve tried, it almost gets thru the program dump then quits.\x3cbr\x3e\x0d\x0a\u00a0\x3cbr\x3e\x0d\x0aBoth radios are 5-watt, 99 ch.\x3cbr\x3e\x0d\x0a\u00a0\x3cbr\x3e\x0d\x0aSoftware version is latest one avail for radio., R.03.02.01 if memory serves correctly. \x3cbr\x3e\x0d\x0aFreq prgm for both are within the bandsplits\x3cbr\x3e\x0d\x0a\u00a0\x3cbr\x3e\x0d\x0aS\x2fN 751ASW0890, and 751ALP0736\x3cbr\x3e\x0d\x0a';
  • 3adam15 Jun 03, 2008
    Prgm cable OK. Got one radio cleared by reading codeplug first, modifying pgr, saving, then pgrm radio (F8)
    Still having trbl w/2nd radio. Reads OK. Serial buss access error 03 when try to pgrm. Rib battery OK. Radio running on battery eliminator in test stand. Motorola svc ctr in Fla. fixed once b4 w/o having to repl any parts.
    Persistence pd off. F2 several times until it read quickly then F8 until program broke thru. Loaded new codeplug data and it went thru w/o delay or error. Check com set up each time (F9). Prgm has tendency to drop serial connection giving 003 error code.
  • 47 Answers
Is the programming lead ok. No breaks
Posted on Jun 02, 2008
How to resolve CODEPLUG ERR on Motorola PTX760
Your radio needs to be reprogrammed or repaired. This type of error can occur for no reason, or during an interruption in programming. Check your programming/test set-up. Do not try to reprogram using the same codeplug (saved version of programming) as previously used, as it may be corrupt. If you cannot get the error to clear with a fresh programming, the radio will need to go to Motorola to have the error cleared.
Best regards.
Apr 12, 2013 | Laird EXL42MX * Motorola PTX760 Motorola...
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
2002 Buick Rendevous intermittent electrical issues
Classic description of a fretting issue. Read this post on the issues GM has with fretting.
Fretting corrosion in electrical contacts Ricks Free Auto Repair Advice
Nov 29, 2017 | 2002 Buick Rendezvous
A program deleted my keyboard and now I don't have one showing when I check the keyboard in my control panel. It works at the very start up but not after. I have tried a new keyboard and windows doesn't...
Generally additional drivers are needed for basic keyboard functionality, although Windows does actually install them as unique devices. Sometimes this process can take several minutes (depending on computer speed) and the keyboard will be unresponsive until it's actually installed. Try plugging in your keyboard, rebooting the PC, and giving it a few minutes once it's up and running.
If that doesn't work you can try booting into Safe Mode by hitting the F8 key during the startup process. This will load generic drivers and will allow you to troubleshoot additional drive and/or software issues.
May 02, 2011 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
1997 Olds Delta 88, 3800 engine, when started and let idle, when the engine hits about 150 degrees, it stumbles and kills. It starts back up. It has killed at freeway speeds several times. Pull off the...
electrical is the weakest link-you may have a computer with issues and before replacin a reprogram should be considered--what did vehicle scan tell you? Data recorders are often placed in cars that show no codes--Older cars can have solenoids and components that heat up and stop engine--if theres a distributer cap-inspec for corrosion
Nov 29, 2010 | 1997 Oldsmobile 88
Sometimes during night several times try to start
it sounds like the fflame sensor needs to be replaced, however if the unit has fan assited combustion you may also have an issue with the pressure switch. hope this helps
Nov 02, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Electrical issues (2 or 3) with Mazda Tribute 2002
hello there, there is a way to check if the alternator works, just start the engine and run it at idle for a minute or so just to get the engine warmed up. while the engine is running, try to remove the positive terminal cable from the battery (note: no lights, radio, or any accessories operating). the alternator should be sufficiently providing power to the engine. if it dies down the charging might be weak. another way is purchase a digital multimeter and setting it to dc voltage testing. put the tester prongs on the correct terminal( positive to red positive and negative to black negative) test the voltage prior to starting. usually it shall read 12. 3 or a tad higher. remove the tester prongs from the battery terminal and start the engine. then place it back on. the reading shall read 14V plus without any load. sometimes it might read 15V w/c is usually over for certain cars. then turn on all accessories: headlights, aircondition/heater and etc. if the reading on the tester indicates 12.8V and above 13V your charging system is ok.(all this test is on engine idle)
For the battery, my experience is that 2 years of battery duty is quite good already. unfortunately, during these span of duty the battery might give a 12V reading but its strength is not enough to sustain the load. the voltage of the battery is the physical attribute so to speak and ampere is the power or strength of the battery.
for your accessories that died, I think something tripped when you jump started it. but the accessories are easily traceble. I think what's important is keeping the engine in tip top condition and won't let you down during hard times.
hope some of this helps you.
May 04, 2009 | 2002 Mazda Tribute
After starting and shutting off several times the truck runs lean
O god sell it quick!!!!!! jusk kidding I had a simlar prob. with a grand prix. start by changing fuel filter. not to sound like an idiot but sometimes when we get smater with car we forget to check the basic. don't know if this will fix it but it a good cheap place to start. next i do a comprsion check on each cylinder. I'm not sure how to do it my friend does mine for me. if there is a big difference in the cylinder it means you have head gaset, bad rings or hole in cylinder. or something in that area. ther probly more people here a lot smater than me that could help you out with this.if all are ok and get about the same reading. then i would guess that you have an elec porb. wich is hard to find could be something like a coolant senor give the wrong reading which tell the compter to give more fuel which alows it to kind of flood ( usually this is show up on your hand held testers) but I WOULD START WITH THE BASICS. I hope tis may get you started in the right direction
Apr 05, 2009 | 1990 Ford F150
My futura sewing machine seems locked up
Try removing the screws that hold the needle plate on and take it off, remove the bobbin case and check for loose thread in the bobbin area. Sometimes machines lock up when a small piece of thread gets under the bobbin case, this is called being "thread locked". Hope this helps. I'll see what I can find out about the "88" error message.
Feb 24, 2009 | Singer CE-200 Quantum Futura Computerized...
Motorola XTNi two way radio red light on all the time
The XTNi is a European version of the Radius CP110 and the Spirit RDX series. This unit is user-programmable. It is possible the radios you have with the same symptoms have a programming issue.
There are 3 ways to program the radio: 1) using the CPS software and cable, 2) using the 6-unit charger as a cloning station, or 3) using 2 single unit chargers linked together via a cloning cable. It is also possible to change limited programming features by hand.
We suggest you take one of your XTNi radios which is functioning correctly and clone the codeplug (copy the programming) into the non-functioning radios to see if it clears the problem. If not, the unit should still be under warranty. Take it back to the place where you purchased it and see if you can get it repaired under warranty. (This unit has only been available for about one year, so yours should still be under warranty.)
One other issue might be effecting the radios, which would be rare to happen on more than one radio at the same time. This would be "lock in transmit". You could tell if this were the case, because the radio's display would not change when you press any of the buttons. This problem would also require repair.
Sep 18, 2008 | Radio Communications
Motorola MT1000 Compatible 2 Way Radio Battery Eliminator Logo
134 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
