Question about Panasonic Lands Phones
My cordless phone for the Sharp UX-CC500 facsimile unit just quit. My battery is good but the phone says LOW BATTERY. I plugged the charger into several other 110V outlets and the phone says its charging but after 12 hours and i take the phone out of its cradle, it still says low battery. I've cleaned the contacts in both the phone and charger. I've narrowed it down to the cord that plugs into the phone unless you have a suggestion? Wes
  • Panasonic Master
  • 16,654 Answers
How do you know that the battery is good?
Posted on Jul 02, 2017
  • 8 Answers
SOURCE: Dropped calls when cordless phone plugged into it.
I have solved this problem several times by using a splitter at the telephone jack instead of the XDP port on the phone. The extension is programmed to share the port isn't it? That is in program 600.
Posted on Sep 16, 2007
SOURCE: I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Posted on Aug 11, 2008
tech4222
  • 40 Answers
SOURCE: tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Posted on Nov 18, 2008
SOURCE: LG chocolate phone/low battery/plugged in/constant beeps
take your battery out & rub on the pins of battery. then put it in the cell phone & switch it on & charge it.
Posted on Dec 26, 2008
SOURCE: Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Posted on Mar 23, 2009
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
Sharp facsimile ux-104 how do i send a fax
with phone line plugged in, insert page face down into machine, dial the fax number, press the send/start key.
Jun 30, 2009 | Sharp UX 108 Roll paper Thermal Fax
SHARP UX-B750 facsimile will not receive faxes and displays the message "NO SERVICE".
Plug a regular phone into the wall jack and listen for a dial tone.
Make sure you are plugged into the LINE port of your fax machine.
Do you have DSL phone service?
Oct 21, 2008 | Office Equipment & Supplies
Fax problem
Hi Fatimo25,
The screen on your fax machine displays how the machine is set to receive calls. TEL MODE means the machine will not auto-answer incomming calls and will operate as a normal telephone device, it will still however be able to send a fax in this setting.
Place your message on the original tray and pick up the handset, dial the number and when the distant machine answers press the start key or ask for their fax machine and when you hear the high pitched fax tone press start.
There is a button on the panel that will allow you to change the reception mode of your machine to the other settings.
Your machine is of a model that doesn't come into this country so I have no manuals to forward you. You can try however to access the SHARP web site www.sharp.ae
Hope this helps you
regards
Gavin
Oct 08, 2008 | Sharp UX CC500 Plain Paper Thermal...
Sharp UX P100 plain paper
Go to this website, http://www.sharp.ca/manuals/ and scroll down to Facsimile, then select your model number UX P105 and on the right hand side you can d/l your owners manual.
Hope this helps.
Good luck.
Please remember to leave a feedback and rating if Ive helped you with your problem.
Mac =)
Feb 10, 2008 | Office Equipment & Supplies
Vtech 8L55 2 unit portable phone
I just had the same problem. Could be dirty terminals. I took the battery out, cleaned the terminals on the battery and phone with a pencil eraser, put the battery back in and it's working fine. (Says fully charged, where just a few minutes ago it said low battery).
Nov 06, 2007 | Vtech IP8100-2 Twin Cordless Phone
CORDLESS PHONES FOR THE UXCC500 FAX ANSWERING MACHINE
You can connect up to 4 cordless sets (Operating manuals, page 21, states 3 but they really mean 3 in addition to the one packed with the base, for a total of 4). I've head four connected for over 5 years now and they work fine. In your case, try disconnecting the battery of the cordless for at least 30 seconds, then reconnect. You may also want to disconnect the power cable from the base unit for a half minute or so. I found this method to be equivalent to a cold boot, and quite effective in getting all phones to work again after a storm or power outage.
Aug 13, 2007 | Sharp UX-K01 2-pc. Combo Addtional...
Problem in work off faxmachin
now lets practice good grammar and speak proper english. unplug and replug printer. Otherwise, get a new one.
Mar 07, 2007 | Sharp UX CC500 Plain Paper Thermal...
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
