Question about Frigidaire Dryers
My gas dryer fires up but does not stay on. FDG546RES3 is my model number.
    President:
  • 1,554 Answers
The problem is with the gas valve solenoid coils sitting on top of the gas valve assembly. One or both are working properly during ignition/start up but fails when heated. This is an easy and cheap repair to make. Raise the top open then remove the front panel to access and replace both coils solenoid coils.
Posted on Oct 11, 2010
Maytag gas dryer not drying cloths
Here's an idea, is your machine in a well ventilated area? Gas powered devices have oxygen sensors that detect when the oxygen level drops to a dangerous level, this shuts off the gas, but not the machine. Put a fan in the room, open the window or door and try again.
Dec 29, 2013 | Computers & Internet
Have a five year old Amana Gas Dryer Model Number NDG5805 that makes a buzzing sound only when it is heating, what could be the problem?
the gas valve coils on the gas valve body that hold the gas valve open to supply gas to fire the burner are getting loose and need replacing
Mar 08, 2011 | Amana NDG5805AW Gas Dryer
My maytag model- MGD5740TQ0 gas dryer burner fires only for 10 seconds and stops; repeats every 2 minutes or so buy does not stay on long enough to dry load
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 22, 2010 | Maytag Dryers
No heat
Based on your description, it sounds as if your gas valve coils may be malfunctioning. This has consistently been the number 1 failure.
This link shows an image of the coils. You will need to provide the model number off your dryer product ID tag.
Tip:
Model Number Locator Tips
1. A zero in the model number might be the letter O.
2. A lower case L might be a 1.
3. Some models have 3 digits and a period first, like this 555.66666666
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i3479&PartID=3479
This link shows parts breakdown and disassembly procedures.
1. http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here are some things that could cause your problem.
2. If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Gas dryer not heating properly
This sounds like the flame sensor is bad to me.
If it does not work properly, the unit will shut off for safety. The machine assumes that the burner did not light and rather than run gas into your house, it shuts off. It may try to start a certain number of times and then shut off.
You may be able to remove and clean it (flame sensor) lightly with a scotch brite pad and it may work properly again.
Otherwise it will need replacement.
This is a very common problem and the part is probably in stock.
Post a comment on your progress as this solution is likely to be useful to many people.
Thanks,
Tim
The problem is not the gas valve.
May 06, 2009 | Whirlpool LGR5636L Gas Dryer
Won't stay lit
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
Mar 07, 2009 | Maytag MDG6000 Dryer
Whrilpool gas dryer
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD OF LAUNDRY. IF THE DRYER WORKS O.K. WITH THE EXHAUST DISCONNECTED, YOU HAVE A RESTRICTION IN THE EXHAUST DUCT SOMEWHERE.
Apr 22, 2008 | Dryers
Dryers Logo
53 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
