Question about Gateway 7405GX Notebook
Gateway Laptop My the Power Cord for my laptop is not charging my laptop. I bought a new one and it doesn't work either.
    Problem Solver:
  • 31 Answers
Check the voltage and the ampage of the charger. Also unscrew the laptop and check if the power connector on board is dissoldered then solder it to the board.
Posted on Jun 02, 2008
Gateway MS2291 wont power up
Did you check the DC Jack where the Power Cord plugs into the laptop? If it is bad (wiggly or loose) then the laptop will not power on. Take an ink pen and put it where the power cord would plug into the laptop and see if the jack wiggles or is broken. If so, that's your problem.
The old power cord might be some good if the problem is with the DC Power Jack.
May 01, 2012 | Gateway Computers & Internet
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
Describe your Gateway M675 Laptop w/ Pentium4 Gateway M675 won't maintain a charge after charging and the display flicks from ac/dc until the battery is completely empty. Do I need a new battery or power...
Sounds like you need a new power adapter.The M675 needs the correct voltage constantly to work correctly.I'm using one right now and it does the same thing with the wrong adapter or a weak adapter(low voltage).M675 is a great laptop but with the 3.0ghz its got to get the power it needs especially when its under a heavy load.
Oct 26, 2010 | Gateway M675 Laptop
Cannot power on, even when plugin the AC there's no lights (no charging)
This is a power problem.
First remove try charging your laptop with another power cord to see if it works
If it doesnt,remove the battery from the laptop and plug the laptop directly into power if the laptop comes on,then the battery is faulty and you should get a new one
But if it doesnt then the charging port is no longer working and you should get a repairer to help you change the charging port
Thank you for visiting fixya
Mar 06, 2010 | Gateway MT6707 Notebook PC
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Hi i have a gateway mt6451 and i can not get it to charge
i am having the same problem with my gateway MT6451. I bought a new battery charger but it still does not work.
Nov 20, 2009 | Gateway M350S Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Power Problem with A/C adaptor on my Gateway M-6816. The light on the a/c adaptor flashes green and the laptop wont charge. This is a new factory a/c cord.
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 17, 2009 | Gateway M-6816 PC Notebook
I have a gateway laptop model mx8715 the cord on the power adapter is broke i bought a tatgus universal charger some times it charges sometimes it doesnt do u have a gateway repair shop to see if theres...
I have a store in Scottsdale AZ. I have seen this many times with not only Gateways but other laptops as well. Not all universal power supplies deliver the correct amerage the laptop requires. Even though the universal power supply has the correct specs, I've measured both the voltages and amperage and found them to be not all that acurate. Your laptop is probably alright. Order a new power supply from MPC. MPC is Gateway's repair agent.
Jul 29, 2009 | Gateway Computers & Internet
Gateway Notebook ML6721 going back and forth between battery & AC
the socket where the cord plugs into the back of the laptop gets wattered out and does not make a good connection when it gets this way. I suggest that not move it so much it kinda defeats the purpose of a laptop. though
Jun 22, 2009 | Gateway ML6721 Notebook
Gateway 7405GX Notebook Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
