Question about Samsung Televison & Video
CAN'T FIGURE OUT HOW TO WIRE MY SAMSUNG HDTV TO A HD CABLE BOX
  • 20 Answers
On the back of your Samsung HDTV there is a HDMI input and on the back panel of your cable box there is a HDMI output.
Connect the cable box and the HDTV using a HDMI cable .
Hope this helps.
Posted on Oct 11, 2010
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Some HD channels won't work on new Samsung tv.
Some hd channels can only be viewed by watching thru a cable box. If you are using a cable box check with your cable provider to see what the issue is.
Dec 23, 2009 | Samsung LN52B550 52 in. LCD TV
Samsung 40'' tv can't get High Def when i connect to my cable plus
make sure your cable box is hd compatible, also depending on the cable box you may have to go through your settings and change the resolution and also change your settings through the menu's on the tv itself. what type of cable box do you have? is it a satellite box? which provider?
Apr 04, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Device code for Samsung SMT-H3050 HD Cable Box
I use an old universal onkyo remote. 0035 Is a Panasonic code but worked the smt-h3050
Hope this helps
May 26, 2008 | Bose Cinemate Digital Home Theater System...
HD reception
To have HD on cable, you will need an HD cable box with the HD service activated by the cable company. Some cable carriers will provide some basic HD services included in the base cost with the box.
From the HD cable box to the TV, you will need an HDMI cable between the cable box and the TV set. This is an HDTV interconnect wire. You will have to refer to the instructions on the cable box and on the TV to get everything going properly.
Jerry G.
Apr 28, 2008 | Sanyo DP26746 26 in. LCD Television
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Hooking up cable through ht-x50
You need an Optical Audio Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
Dec 05, 2007 | Samsung HT-X50 System
Protron HDTV Cable hook up
if u want true hdtv buy a samsung 1080P LCD
Nov 11, 2007 | Intel VOICE D41JCTLSEURO PFU CT LSGS Comm...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Televison & Video Logo
130 people viewed this question
Jerry Greenberg
Jerry Greenberg
