Question about Toshiba 52HM95 52" HDTV Projection Television
Has poor picture, Bulb works. Screen has dark picture with small dots. The color wheel don't seem to turn. Would the board on the light engine be bad. ? . looking for the service manual.
    Sergeant:
  • 171 Answers
Hi there it sounds like you have a problem with the DMD board it sounds like some of the micro mirrors are getting stuck in the on or off position and that is the reason you get the dots you need to replace the LIGHT ENGINE to fix this problem
sorry I could not find the service manual
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!!!!!
Posted on Oct 11, 2010
Testimonial: "Great fast help of problem. Thanks very Much."
How to fix Samsung HL72A650C1FXZA DLP TV with no sound, no picture, bright screen with lamp light flashing?
Check the bulb ballast board. It's the board that the wires from the bulb connect to. That is most likely causing the Sounds like the main board is the culprit for most of the problem. The picture problem can be the color wheel not turning. The lenses in front of the bulb should be taken out and cleaned too.
Oct 12, 2016 | Samsung Televison & Video
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
I have a 50 in RCA older HDTV that is experiencing a darkness in a V pattern starting in the middle of the bottom of the screen. I am told that it is not the bulb but possibly a circuit board? HELP
i have seen a few of these and not seen that cuased by a curcit failure.(OF coarse nobody has seen it all) I would suspect something in the optical path. what i mean by this.... the bulb shines light through a color wheel into the engine then through a lens bouncing off a mirror then on the screen. now is the picture visable through the dark area? their could be something inside. blocking the lens(dirt,bug,fly) or there might be a broke mirror. also the screen could of got wet and damaged.. dont know exactly but these are my best guess without seeing the picture... let me know how it goes
Oct 22, 2010 | RCA HD50LPW175 50" HDTV
Small blue dots clustered when the screen is dark, near the projection point.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 29, 2010 | Sony KDF-E50A12U 50" LCD HDTV
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
Red dots all over screen poor picture more when
This is a "mal-discharge" fault & will need either an adjustment on the Y-Sustain board or a software update to the control board. Contact your LG dealer to arrange someone to sort this out for you.
Oct 26, 2009 | LG 42PC3D 42 in. Plasma Television
Very slow to turn on and has small light spots all over screen
The first thing to look for are swollen capacitors on the power board.replace them if so.
Sep 11, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Color wheel replacement
With the back off of the unit, you are looking at a silver can on the light engine. The is the board where the DLP IC is located. There is a large heat sink right in the middle. Near that heat sink you will find a small square cut out where two pins protrude from the inner bd. There is a small black piece across those two pins, that is the jumper. With a needle nose slide that black jumper off of the two pins. Normally if the color wheel is changed and the jumper not remove the picture is very poor with ugly green and purple negative look.
Jun 15, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Poor picture quality in new Akai plasma TV
This might be caused by bad interconnections maybe try using a different cable i hope your not using analog.I was told that the red dots are usually caused by interconnects such as analog.
Sep 16, 2007 | Akai PDP-42TD1 42 in. EDTV-Ready Plasma...
Toshiba 52HM95 52" HDTV Projection Television Logo
393 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
