Question about Minuteman C82906-01 HEPA Vacuum Vacuum
Does not pick up, no vaccum, motor runs, no blockage, should feel suction on hose outlet without hose hook up. Paper filter missing over cloth filter. float overload ball free, seal on section good no leakage. Maybe bad motor but runs.
  • 1,040 Answers
Here is a Link to one of my Tips:
www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
This should solve the problem.
Good Luck!
Jim
Posted on Oct 12, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
I have a DC41 Animal. It has suction through the hose. When I try to vacuum it stops sucking through the hose but seems to have no suction in the base and the beater roller doesn't work.
Check for a clothes peg at the motor iintake port. They can get that far then jam at the curve so tight youll wonder how you missed it. It will drastically reduce suction yet not cause a clog , and you can't see it
Feb 09, 2017 | Dyson DC41 Animal Bagless Upright Vacuum...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Hi, my Bissell 3920 has lost almost all of its suction. I checked the hoses and tubes but did not find any blockages. Filters are clean. Thanks.
Hi, Have you checked and made sure the floor plate is secure and tight without any gaps around the edges? If that's ok then check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself
Nov 27, 2011 | Bissell 3920 Bagless Upright Vacuum
No suction
well, it actually sounds like there is a blockage. Try removing your hose and dropping something through it, like a quqrter. If it comes through, no clog. If it is clogged, I believe that machine has a blower on the upper part of the cleaner (maybe in the bag compartment towards the top. You can take out the filter holder and plug the hose in there and run the unit . Does the blockage come out? If not, Try shaking the hose, or you can put a stiff wire in it to try to free it. Do not run water through it. If there is no blockage at all, then you will probably need to take it to a service center. But I am pretty confident that we are looking at a clog situation. Let me know if this fixesya! Thanks, Rene (vacuum Doctor)
Nov 14, 2009 | Miele S514 Solaris Electro Plus Vacuum
HOSE HAS NO SUCTION - VACCUM WORKS JUST FINE - DC14 MODEL
Hi
There must be a blockage in the hose.
Check the hose from the pickup,just behind the rotating brush all the way to the dirt collector.
Push a length of wire with the end bent into a small hook(similar to a fish hook) to pull out any blockage.
Regards
Phillip
Oct 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vaccum cleaner not picking up (116.36933/Aspiradora)
Joan,
I had a similar problem with my upright and just resolved it today. Mine was also picking up with the beater bar, but not as good as it should and it had very little suction at the hose.
I did everything it said to do in my owners manual...
I looked into every entry to the dirt cup.
I checked for blockages into the bottom of the vacuum.
I cleaned the HEPA and regular filters and dirt cup - still no success.
I made sure the belt was working properly.
I finally sat and looked at how things should get into the clear dirt cup (bagless model).
I finally realized it had to be a blockage in the hose.
I completely detached the hose from the vacuum - this took some muscle.
Took the hose outside and used my high pressure nozzle on my garden hose to spray out the hose. It took a few seconds before a pretty large & stiff piece of paper (2"x2") and much more very dirty stuff finally blew out...
No wonder the vacuum had no suction!!!
The paper that was blocking the hose reminds me of a piece found under a Reese's Peanut Butter Cup! YIKES, it was probably candy causing yet more problems besides the extra pounds!!!
Hope this helps - I'm not an expert, just a frustrated cleaning fanatic who hates it when mechanical things don't work right!
Good LUCK!
rtwospeed in Henderson, NV
May 27, 2009 | Kenmore Vacuums
Hi, Fitted new paper bag to this cleaner but have 'No' suction. With bag removed no air movement can be felt at outlet(ie bag entry). Have you any suggestions?. Many thanks, John Pessall.
What kind of model is it?
If you have the bag door open just to feel if there is suction it won't work. The machine would have to have its door put back on before suction can be ascertained. In the meantime check the hose that leads into the bag, or main dust channel - it may well be clogged as well as motor filters usually located under the paper bag.
Mar 02, 2009 | Vacuums
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Not picking up
Did you check down by the brush roll? If the hose has suction, then the problem has to be in the nozzle asm. The hose having suction tells you that the main part of the vacuum is working ok.
Mar 17, 2008 | Eureka 7618 Bagged Upright Vacuum
Minuteman C82906-01 HEPA Vacuum Vacuum Logo
106 people viewed this question
Top Minuteman Vacuums Experts
JoeVacs
Are you a Minuteman Vacuum Expert? Answer questions, earn points and help others
