Question about Kenmore Refrigerators
We have a kenmore model 79142 and it has developed a loud vibration in the freezer area it is cooling good but very noisy
yeroc
  • 397 Answers
SOURCE: Sub-Zero 550 Fan Vibration
you could try taking the fan assembly out and adjusting it or oiling it, sometimes it gets that back pressure when the door is closed because it has to work harder
Posted on Jan 20, 2008
  • 260 Answers
SOURCE: Kenmore side by side freezer not cooling
try removing the panel in the freezer. you will see an evaporator fan . test it and the thermostat beside it it is one of the two
Posted on Apr 09, 2009
  • 82 Answers
SOURCE: Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Posted on Jun 26, 2009
mgprice
  • 744 Answers
SOURCE: My freezer was developing frost / not cooling very good.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! and thanks for using Fixya. Mike
Posted on Jul 29, 2009
SOURCE: kenmore elite french doors bottom freezer Model #
Well you got a kenmore that i believe is actually made by either Samsung, or LG, since Kenmore does not make any refrigerators, they are ALL taken from other name brands with the name kenmore put on the front. I would start by looking at your owners manual for troublshooting codes, but chances are you have a faulty evaporator fan motor, either the motor itsself is out of balance, or possibly ice is obstructing fan blade, and you'll need to find the source of that problem instead. hope this helps
www.FixMyFridge.net
Posted on Mar 08, 2010
I have a kenmore coldspot model 70167998 - loud vibration in freezer; i'm thinking maybe it's the frost free fan going out? Is this a fire danger?
no theres not any fire danger,it may just be the fan blades hitting ice build up due to defrost issues you will need to remove the rear inner wall in the freezer to see exactly what it is
Jan 31, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
My brand new Danby compact chest freezer is very noisy.What is the problem?
It could be an area where the tubing is vibrating against the cabinet or it's touching other tubing. While it's running you can run your hand along the tubing and when you get to the vibrating area it should stop. You can then slightly move the tubing away from where it's vibrating. Do not bend or kink the tubing.
It could also be a noisy compressor which would be under warranty.
Aug 26, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Kenmore Coldspot freezer is buzzing loudly
See if pressing on the back panal makes a difference and see if anything is putting pressure on the panel. If its vibration it is trial and error to get it positioned to quiet it down. If it is the bearing replacement is the cure.
Eric
Jul 03, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Nov 23, 2008 | Kenmore Freezers
Kenmore Top...Brand new, loud icemaker & door vibrating
you may think its comming from the door but check the back of the frige it could be your cooling fin radiater if we can say when you here the noise listen closly then touch the tubings or the radiater in the back you will find where its coming from it may be a loose scew causing vibration
Sep 26, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore refrigerator is noisy
my kenmore fridge is loud everytime the compressor comes and stays on. I have developed tinitis in the year because of this noise. Solution to this problem : I will never ever buy another Kenmore refrigerator.
Mar 05, 2008 | Refrigerators
Jan 20, 2008 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
