Question about Canon Rebel XT / EOS 350D Digital Camera
Loading cf card
My wifes got a Canon Digital Rebel 350d, she took the cf card out and went to put another in but it wont go in, the little lever that you push to eject the card seems to be stuck down, we've tried everyway to get it in but no luck, any idea's ?
    Novelist:
  • 130 Answers
If you look inside the slot, are any of the pins bent? If so, you will want to get that serviced either by Canon or someone you trust. If it's under warranty (1 year) I suggest calling Canon.
Hope this helps!
Posted on May 31, 2008
I took my CF card out to get photos, went to put it back in and the screen read "There is a problem with CF card. Replace the CF card." I didn't think there was a problem with the card. But I replaced...
Your CF pins in the camera are most likely bent/broken. This is a very common problem. Most repair shops will charge $150-$200 to repair this.
Hope this helps.
Wes
Sep 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
No Power To Canon Digital Rebel XT
I believe this post will help you out..
Please CLICK HERE
May 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Formatting a SanDisk for my Canon Rebel Xt failed
Formatting the card completely erases it. Your pics are gone.
Feb 22, 2010 | Canon Rebel XT / EOS 350D Digital Camera
After I removed Cf card I inadvertently pressed
Have you tried inserting the card while pressing the remove button at the same time?
Feb 12, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Aug 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lost previous pics after checking used memory on CF card
have you used the card since if not there is a program you can download that can help recover the datahttp://www.pcinspector.de/Sites/smart_recovery/info.htm?language=1
Feb 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF
the only possible for this error is. where the cf plugs into. the pins at the bottom of the CF chamber are bent. A close inspection with a good light should confirm this
Jun 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT unable to access compact flash card
check all the pins in the CF socket in the camera are there, or are not bent, repair is expensive if broken
Jan 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Change out the CR2016 3V battery. You have to remove the rechargeable battery to get to the CR2016. Refer to the manual for proper instructions.
Had the same issue with a two year old camera. This solved my problem.
Nov 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon ds6041
The error 02 can come up when there is CF card problem : card not seated properly , card takes too long to come on line from the cameras point of view or if one of the the pins inside CF card chamber is faulty.
Sep 12, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
150 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
