Question about Transcend StoreJet 25 Mobile 500GB USB 20 25'' External wOne Touch Backup (Red) 500 GB Hard Drive
I have a transcend storejet elite. I accidently unplugged it when it was doing a back up. now when I plug it in it says the zip file is corrupt, and there 0MB in the memory size column.Can I get the documents back?
  • Transcend Master
  • 7,733 Answers
TRY MNINITOOL.COM AND FIND THE RECVERY FREEWARE.
Posted on Oct 12, 2010
  • katburrow Oct 13, 2010
    thanks. I'll give it a go
Memtest usage error
move all files to computer..format hd..more bk files to hard drive
Jan 29, 2014 | Transcend StoreJet Computers & Internet
I have a Transcend StoreJet 25M 500G external, I have a problem because when I plug it to the computer it will just display a shortcut icon, I can't access anymore my folders saved. This happen wh
the attributes of your files and folders have changed, go to folder option, then click show hidden files, also uncheck show system protected files,..........download some attribute changes software for changing the attributes
Feb 04, 2013 | Computers & Internet
My external hdd transcend 320 gb storejet is very slow while copying file to or from the hd and the blue LED keeps on blinking what might be the problem??
Well u may have it plugged in USB slot but needs to be USB 2.0 .if in regular. USB..will run slow...also external he'd when u not using. It unplug. From USB and AC plug...not good to just let run..they will were out..defrGment hdd to.good luck
Dec 21, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Unable to open the folder in pendrive
The "Personal Data" folder stores all necessary data for StoreJet elite software use (including elite backup files storage). If you would like to backup files into personal data folder, please refer to the manual to use data-backup function.
(http://www.transcend.com.tw/Support/DLCenter/Manual/StoreJet_elite_EN.pdf).
Please do not manually store other data inside this folder. It might cause the software/system to function abnormally. We suggest user to store data at other different folder/path, and avoid occupying "Personal Data" folder. blackbar_left.jpg Print blackbar_right.jpg
Oct 28, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My Transcend StoreJet 320 GB USB 20 Hard Drive is having a problem When i connected the drive to my laptop it got detected for sometime and then disconnected automatically
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Hi, i can't download some files to my transcend elite storejet 500GB, it's says the file is too big, but the file is just 5.49 GB and free space in hard drive is more than 400 GB. what to do?
You drive is formatted for FAT32. What that means is the way data is stored on the hard drive is an older method that does not support files over 4GB. The benefir of FAT32 though is it can be read and written in both Windows and Mac. If you hate mac (as we all do) then screw FAT32. I almost forgot, if you use this hard drive with the xbox 360 do not continue as the xbox 360 for some ******* reason 360s can only read FAT32. The new format we are going to go to is called NTFS (new technology file system) which is made by microsoft, makers of the xbox 360. lol
Anyway first backup everything you have on that disk. Either on a computer or burn it to DVDs cause if you don't you will lose everything.
Plug in the drive, right click on My Computer (or its just "computer" now) click manage. Go to disk management on the left pane. It will take a minute to detect all your drives. You will see your 500gb drive. Double and even triple check it is your transcend drive. Right click it and click format. Change File System to NTFS.
Apr 06, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
Cant read a folder in a hdd transcend storejet 2.5 110gb
Looks like you probably have some corruption on that disk. Assuming it isn't physical damage on the disc, running a CHKDSK on that entire drive may fix that for you.
With the drive plugged in, open My Computer, right-click on the drive and select PROPERTIES. Then click on the TOOLS tab, click CHECK NOW, check both boxes then click START. Let than run and it will tell you when it is done. Once it is, try opening that folder again.
Jan 21, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I have a Transcend StoreJet Elite, for some reason I cannot security protect the unit. each time I try, it comes up with an error message. Any ideas. Regards, Bunny.
I think your pen drive is not formated properly. i recommended you that first copy all the important files from the pen drive and store it to the hard disk. Then go to run and type cmd
the type command  as format d:
note that d:=drive specified to pen drive. Formatting from cmd is reliable .
Oct 31, 2009 | Transcend STOREJET 2.5 HI- SPEED USB...
Dropped StoreJet 2.5
Drives are very delicate. If it has been dropped, I'd copy everything off and bin it. You could buy a new drive itself and put it in the Transcend case - saves money :-) It sounds like the drive heads would have been damaged by the drop.
Aug 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend StoreJet 25 Mobile 500GB USB 20 25'' External wOne Touch Backup (Red) 500 GB Hard Drive Logo
454 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
