Question about Connecticut Electric Square D Packaged Circuit Breaker
No power to the receptacles on a circuit, the breaker isn't tripped. there are no GFI's
No breakers are tripped and a circuit is dead.
There is a loose wire.
Let me explain how it works. Each 120V breaker has a black wire that leaves breaker box. The black wire is accompanied by a white neutral wire and a bare ground wire. These wires are sheathed in plastic, and altogether they make up a romex cable.
The cable leaves the circuit breaker box and travels to the first junction box. The junction box is a ceiling box that holds light or fan -or- a wall box containing switch or plug. As a general rule, the romex leaves the breaker box and travels all the way to a junction box located right in the area where lights and plugs are located. The romex does not stop at a junction boxes located in other room.
Inside the junction box, the romex splits and goes to the next junction box, and then to the next box, and the next.
So the plugs in one room are all connected together by a single romex cable that started back at the breaker box. And a single romex wire from the breaker box arrived at one of the junction boxes located in immediate vicinity of dead receptacle.
Here's what happened. A wire came loose somewhere between the breaker and the dead receptacles.
The loose wire is probably in a receptacle.
Here's what to do.
1) Breaker first: You can isolate the suspect breaker by identifying all other breakers. Then tighten screw on suspect breaker. Look for white wire and ground wire associated with the romex cable that connects to breaker >> tighten those screws on neutral busbar. Look for burning around suspect breaker. Is there a burning smell indicating breaker is bad?
2) Receptacles Next. Use ordinary tester. Test each receptacle. Receptacle has two rectangular prong holes and one round hole located below other two. The round hole is the ground. Breaker is turned on. Test each rectangular hole to ground. You have to test both prongs to ground.
The loose wire is right there in the vicinity of dead receptacles.
Test one receptacle and then move to next receptacle. At some point the tester will light up. Now click suspect circuit breaker to see if that receptacle is on breaker. Test receptacle with breaker off and breaker on. If that receptacle is on the suspect breaker, then a loose wire is inside that receptacle box >> or inside the next box. Many times, the wires are pushed into 'quick-connects' located on back of receptacle ... wires get loose ... you need a small screwdrive to release quick-connect, and then wrap wire around screw -or- replace receptacle
If none of receptacles show electricity, then loose wire is inside a switch box, or it is inside a ceiling box located in same general area. Check your switches first. Look for quick-connects, or signs of burning. Look for loose wire nut. Plug light into dead receptacle. Pull switch out with wires attaches. Power is on. Move switch around to see if dead receptacles shows electricity. Move to next switch. The loose wire is there somewhere.
Finally the ceiling box. Take down light and see if there is a loose wire inside. Look for signs of heat or burning.
Posted on Oct 11, 2010
  • 21 Answers
All of the previous solutions to your problem are of very sound advice and should be used to troubleshoot your specific problem. I just wanted to add to the list of solutions given. I had a circuit in my home that when the breaker was off and voltage was tested at the switch, I still had a reading of .6 v , and with the breaker on, a reading of 40v. Non of the lights or plugs would operate on the circuit. I then traced the wire on that breaker from the problem lights and plugs, back to the breaker, finding a compromised splice in the wire. The splice was cleaned up and respliced, and low and behold, the problem was solved. Good luck to you....
Posted on Mar 12, 2014
My DW384 circular saw keeps tripping the GFI receptacle
Most houses have all the outdoor GFI outlets on one breaker...perhaps you can try another power tool with a similar draw to check if it is your saw or the GFI causing your problem. I can't see bad brushes causing a breaker to trip... the saw would just stop working.
Jun 20, 2010 | Dewalt 814 Inch Circular Saw
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
All of a sudden, no power. will not start, no warning.
Before looking into your built-in dishwasher as the problem, check your main electrical panel to see if you have tripped a circuit breaker. If not, you may have tripped a GFI receptacle located on or around your kitchen counter.  If so, reset it! Then try the dishwasher. However, if this IS the problem, this may become an ongoing problem. I agree with (and its code) having a GFI breaker in your kitchen.  But what I don't agree with is when the contractor/electrician who installed this, didn't take into consideration that when these GFI's are put in series with other receptacles (for added protection) in the kitchen, they trip more easily when plugged in with certain appliances because of the motors (eg. refrigerators, dishwashers, etc.) in them. The GFI's sole purpose is for protecting you around the sink where there's running water. It trips on milliamps so you won't get electrocuted around the sink. Also, if you have other appliances running at the same time the dishwasher's running, makes them more susceptible to trip. So in conclusion, first check for power. Second, check for GFI breaker (or vice versa). I believe you should find your problem here. If so, reset it and wait to see how and when this does it again. GFI breaker's are sensitive breakers. They tend to wear out before a regular outlet (receptacle) does. Not knowing how long and old this (GFI) receptacle is, I'd replace that if it happens more frequently. This usually does the trick. I hope it's not your built-in dishwasher. If so, feel free to contact me again, and I'll help you with that too. Good Luck with this, and I hope you get everything back in working order. Take care, Jim
May 22, 2010 | KitchenAid 24 in. KUDS02FR Built-in...
Our hot tub keeps tripping the gfi breaker, but if we don't put it on a gfi then it works fine. How do you fix this
The GFI is sensing a fault, and tripping to protect you. If there is another GFI in the circuit somewhere then you could use that normal receptacle. I mean if there is a GFI in the main panel.
Please Vote !!
Apr 19, 2010 | Balboa Instruments Duplex Digital Panel 2...
Trips GFI circuit brakers
First of all, lets clarify what is going on. You say it trips the GFI breaker, so I'm assuming that it is not a GFCI receptacle that you are plugging into. So you are going to the electrical panel and resetting the GFCI breaker.  If it were a GFCI receptacle, have you tried other loads in this receptacle for 30-40 seconds, ie: Toaster, hairdryer, coffee pot? If everything works fine then there is something wrong with the ESP8XL. It would seem that there is a leakage path to ground from one of the conductors. If it is new, bring it back.
Jul 30, 2009 | Breville ESP8XL Espresso Machine
Pump trips breaker
If the seals are damaged, water will leak into motor section and cause GFI to trip and yet the pump will seem that it is running fine if plugged into a non-GFI receptacle
May 28, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Jan 02, 2009 | LG WM2016C
Trips GFCI receptacle for laundry circuit.
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
Nov 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Connecticut Electric Square D Packaged Circuit Breaker  Logo
359 people viewed this question
Top Connecticut Electric Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Connecticut Electric Electrical Supply Expert? Answer questions, earn points and help others
