Question about GE Dryers
I have no heat to my electric GE dryer,everything else seems to work properly.
  • 171 Answers
Before you start taking anything apart goto your breaker box for the house and check the breaker for the dryer. This will be a double breaker as it requires a 220 volt hook up to run the element. Make sure both of the switches for the breaker are reset ,I always reset both as it is somtimes hard to tell witch one it is. After you have reset the breaker go back and try the dryer again if it is working then great if not start with the heating elements behind the drum, if they are not broken check the cycling thermostat under the lint filter, these were known to have the wires burn off and char the thermostat...Hopefully this works for you and if so please try to click yes and give me a rating ....thank you and good luck!
Posted on Oct 11, 2010
My GE gas Dryer does not iginite and get hot. It turns or tumbles but does not get hot. Checked gas line everything ok with gas line. please provde step by step instraiuctions to replace the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Dryers
No heat to the dryer. Everything else seems to function properly. Frigidaire AEQ7000ES1. Receiving E9 Error code.
heatman101]][
Jul 18, 2011 | Frigidaire Electric Dryer
GE dryer starts up ignitor gets hot you see flames everything is working. 2-3 minutes later the flame goes out. Is this a bad thermostat?
heatman101''';;
Apr 22, 2011 | GE DRSR483GD Gas Dryer
I have a Kenore dryer, model 110.C6549. Everything seems to be working but there is little to no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | Kenmore 62602 Electric Dryer
My GE Dryer.. serial number GL 733 568A. Do not dry clothes, everything else work, except getting hot enough to dry. The dryer just blow cool air..
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 | GE Dryers
The dryer is blowing cold air. Everything else seems to be working properly.
heatman101
Sep 28, 2010 | Whirlpool Dryers
My dryer won't heat up, it spins does everything else but it won't heat up. What could be the problem?
heatman101
Sep 05, 2010 | GE Spacemaker Washer and Dryer Electric...
Mod dpsb613ed2ww bought a used dryer and it does the same as my old dryer, it does not hear everything else workd
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 30, 2010 | GE Dryers
Heating element inop no heat to dryer everything else seems tobe working where can i buy part and where is located in dryer
heatman101
Aug 16, 2010 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
55 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
