Trying to locate jumper to reset bios password , where r they located
  • 27,725 Answers
During the boot up process you will see on the screen press delete to enter set up
Press either delete during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Posted on Oct 11, 2010
Dell d340. need to enter admin password in bios to reorder boot sequence to accept usb first - its locked and i cant remember password. tried removing cmos battery and replacing but no good. help!
Try the backdoor password Dell
With a PSWD Reset Jumper Step 1Open the access panel to the password reset jumper if your Dell laptop has one. Consult your manual for the access panel's location. Some access panels have a tab you slide, while others are held in place with a screw.
Step 2Pry the plastic cover off the reset jumper with your fingernail. The reset jumper is a small pin port labeled "PSWD" with three pins. Put the plastic back onto the jumper over pin 1 and 2 instead of 2 and 3. Wait 90 seconds.
Step 3Pry the plastic off the reset jumper again and place it back onto the number 2 and 3 pins. Turn the laptop on. Repeat step 2 if the password is still present. Leave the plastic clip on pins 1 and 2 for a longer duration than last time.
Without a PSWD Reset Jumper Step 1Locate the reserve battery, also known as the CMOS battery, if your Dell laptop is not equipped with a password reset jumper. The CMOS battery's location varies among Dell laptop models. Consult your manual for the battery's location on your specific Dell laptop model. Many Dell reserve batteries are located underneath the main laptop battery. Remove the main battery and look for a sticker under it with instructions on removing the secondary CMOS battery.
Step 2Remove your Dell's reserve battery per the instruction manual or sticker located under the main battery. Removing the reserve battery resets the laptop's BIOS password. Wait 90 seconds, then replace the reserve battery. Reconnect the main battery.
Step 3Press the "Power" button to turn the laptop on.
Here is some youtube video with your problem:
http://www.youtube.com/results?search_query=dell+bios+password+reset+laptop&oq=dell+bios+password+reset+laptop&gs_l=youtube.12...2937.2937.0.5179.1.1.0.0.0.0.44.44.1.1.0...0.0...1ac.2.rXrXigbVpXM
Try also to call dell support in your country
They will be glad to help you out.
Good luck
Nov 08, 2012 | Dell Computers & Internet
Where can I find my jumper to reset my bio password on my hp computer?
On the edge of the motherboard - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.
By the CMOS battery - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual cmos battery.
By the processor - Some manufactures will place the jumpers by the processor of the computer.
Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
Other visible location - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location.
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
hope this helps
Jan 10, 2011 | Computers & Internet
HannStar J MV-4 (jumper clearcmos/reset bios) password initial wrong setup bios heeeeeellppp.
The location of the jumpers or dipswitches may vary; however, here are some locations of the jumpers / dipswitches.
  1. On the edge of the motherboard - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.
  2. By the CMOS battery - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual CMOS battery.
  3. By the processor - Some manufactures will place the jumpers by the processor of the computer. However, note that in some cases these jumpers will be to change the processor and not the password.
  4. Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
  5. Other visible location - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location.
  6. Jumpers may also be found underneath or allongside the memory modules.
I hope this helps but suggest that the manufacturers web site or your instruction manual, may have the answer.
Oct 23, 2010 | Computers & Internet
Bios password problem on a hannstar j mv4 94v
you will need to get to the jumpers for bios to be able to reset the password or remove the password, this is easy with a desktop computer, but if you have a laptop but you think you guys can open the laptop and locate the bios or cmos jumpers then go ahead.
On the computer motherboard locate the BIOS clear / password jumper or dipswitch and change its position. Once this jumper has been changed, turn on the computer and the password should be cleared. Once cleared, turn the computer off and return the jumper or dipswitch to its original position.
The location of the jumpers or dipswitches may vary; however, here are general locations where these jumpers / dipswitch may be located.
Jun 03, 2010 | Computers & Internet
How do you get the password off of the
There are two ways to reset the boot or the bios password:
1.By removing the CMOS battery
You have to shut down the computer , disconnect the power plug and open up the unit and locate the CMOS battery ( which usually looks like a coin) . Carefully lift the battery out of its socket and set it aside.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
2. By using the motherboard jumper
Shut down your computer and disconnect the power plug. Identify where the jumpers are located. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. Then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down! Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.
For detailed instructions and snapshots u can check up this link :
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Mar 15, 2010 | Computers & Internet
How to change system bios password
You can reset bios password with 2 method.
(1) open cpu cabinet cover then find motherboard .Pull cmos cell from motherboard for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherboard named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks for using FixYa.
Feb 12, 2010 | Mirra M-120 (MIRRAPERSONALSERVERM120)
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
How do you remove the bios password from a dell inspiron 6000 My aunt died and she didn't leave the password behind.
open the rear door on the laptop remove the RAM and locate the 2 pins or Bars in the well where the RAM was.Take a paper clip and short the 2 pins adn then replace the RAM close the door and restart unit.That's it!
Please rate our help to keep the service online++++Thanhks for using FIXYA
Sep 21, 2009 | Dell Computers & Internet
Forgot BIOS password
Question: How to clear an unknown BIOS password.
Answer: If you have mistakenly forgot or lost your BIOS password or you receive a password at boot that you do not know, you will need to clear the BIOS password by one of the below methods.
Precaution: When inside the computer please be sure of the potential of ESD.
  • Try using generic BIOS passwords. A complete listing of these passwords can be found on document CH000451.
  • There are utilities designed to help bypass BIOS passwords. An example of a great utility to decrypt / bypass BIOS passwords is the PC BIOS Security and Maintenance toolkit, which is available by clicking here.
  • On the computer motherboard locate the BIOS clear / password jumper or dipswitch and change its position. Once this jumper has been changed, turn on the computer and the password should be cleared. Once cleared, turn the computer off and return the jumper or dipswitch to its original position.
Additionally, when looking for the jumper / dipswitch the label of that switch can be anything; however, in most cases will be labeled CLEAR - CLEAR CMOS - JCMOS1 - CLR - CLRPWD - PASSWD - PASSWORD - PWD.
  • On the computer motherboard locate and remove the CMOS battery for at least 10 minutes allowing the computer to lose its information. Note: this will not work on all computers.
  • If your manufacturer has a bypass password this can be entered and allow you access to the BIOS and/or computer. Because of the security risk of a bypass password, generally only older computers will have this option. In addition, it is likely that this information will only be able to be obtained from the computer, motherboard or BIOS manufacturer.
  • On the computer motherboard locate the CMOS solder beads and jump the solder beads to clear the password. The identification and location of these solder beads can vary and if not available in computer documentation is generally only obtainable through the computer manufacturer.
If one of the above solutions do not clear the password or you are unable to locate the jumpers or solder beads, it is recommended you contact the computer manufacturer or motherboard manufacturer for the steps on clearing the computer password.
Sep 19, 2009 | HP Compaq 6710b Notebook
Forgot bios password
does your laptop have a 25 pin serial port?
Jun 27, 2009 | Toshiba (P000191710) for T4850 Sound Card
Computers & Internet Logo
541 people viewed this question
David Payne
David Payne
