Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Jenn Air Dishwasher Model JDB1100AWS Light Normal/Extra Rinse are the only two buttons that work.
Hello. As stated above; the only two buttons that work on the unit are the Light Normal/ Extra Rinse. All other buttons do not light up. I cut the power to the unti hoping it would reset. It has not. Unit is working well expect I can't use any of the other features. Any suggestions?
Have you solved youre problem ? i have a dead 11000 series unit no one has any input so much for trying to save a buck.time to switch to paper plates i had a bosh before this i went through 3 contol boards then threw it out i miss the old manual controls
Posted on Jul 14, 2008
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Same thing happened today
with the door open when your dishwasher was working normally Did the lights light up on the keypad? I am wondering because if the answer is the keypad only worked with the door closed .....you possibly have a bad door switch.
or it could be a blown fuse inside the dishwasher. are any lights on at all?
Jun 12, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
No Water in. Will not change wash cycles
There was soap particles caught under the float valve. Thanks.
Jim
Mar 03, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
JDB1100AWS not rinsing
if your filter assembly is clogged you are going to need to clean it. if it is really bad then it should be replaced. the part number is 99003292 and would probable cost about $30. the other thing is start your dishwasher on a rinse cycle and see if you have suds in the bottom do not put additional detergent in while checking this. if you have suds run vinegar in the dishwasher to help get rid of the suds as that can cause the same problem. Let me know if you need additional info
Jan 11, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Jul 08, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Jenn-Air dishwasher jdb1100aws problem
I hate to sound like a broken record. But look for my vinegar and CLR fix. In my experience in most cases that works.
Thanks
Kashif. A
Mar 07, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
778 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
