Question about Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch SHU66C02UC/14 dishwasher that leaves a white deposit on the dishes especially plastic drinking glasses. Suggestions are that it is not dispensing enough rinse agent. How can I adjust that or determine if that is the problem?
    President:
  • 1,140 Answers
This could simply be a detergent problem, but is most likely due to a low salt level in the water softener. The salt is used by the water-softener to prevent hard-water deposits which result in white stains on crockery and glasses. There are several things which can cause this:
1. There is no salt in the salt container.
2. The lid on the salt container isn't screwed on properly. (Don't overtighten though!)
3. Water softener is set too low
If you've checked and topped up the salt level and the lid is screwed on fully, then your water softener may be set too low. You should consult your user manual / installation instructions to change the setting.
The white deposits can also be caused by the rinse-agent being set too low. On your washer, the adjustment will be on a dial under the flap where you refill the rinse agent. I think it's numbered 1-5, so if it's set on 1, try number 3, if it's on 3, try 4 or 5. You may have to adjust a couple of times until you get it right.
If this doesn't solve the problem, try changing your detergent. Check the packaging and if your using phosphate-free detergent, try one containing phosphates. Phosphate-free is more eco-friendly though!
Posted on Oct 11, 2010
Samsung dishwasher sprays gunk all over my glasses. When the cycle is over they are coated with dried bits of gunk. Dishes are dirtier than when they went in.
I have the same problem with gunk and spots on dishes. I took apart the parts at bottom covering the heating element. There is all sorts of gunk on everything. I cleaned it all, even under gaskets and filter screen. I am neither sure what caused it nor how to prevent it. My thinking maybe the water source. Water in my town has gotten worse in quality and has bad smell. I use a major water filter system for drinking water. My thought is that the heating element is drying the water up and leaving sediment from water.
Sep 29, 2012 | Samsung DMR57LFS Stainless Steel Builtin...
Milky residue on dishes, especially glasses
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jul 28, 2011 | Bosch Dishwashers
My dishes are coming out with a kind of film on them -- especially the silverware and glasses. Now the plates even look like they have a film on them. The dishes are often still dirty.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 13, 2011 | Bosch Dishwashers
Calcium like deposits on plastic and glassware after cyc
Check the quality of water used in the machine. If water has hardness this may happen. Use water softener attached on line to the dish washer.
May 19, 2010 | Magic Chef 24 in. DU2000 Built-in...
Making noise and leaving white film on dishes
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
the white film is due to hard water. go to www.dishwasherfilter.com and get the new difi filter. it will solve your problem imediately and extend the life of your dishwasher. the product is amazing and guaranteed to work. very affordable
Mar 29, 2010 | GE Nautilus 24" Built-in Dishwasher
My whirlpool dishwasher is leaving a white hard film on glasses. what do I need to do to stop it
Try a rinse agent. You will have a reservoir in the door of your machine. Fill and see it that helps.
In some areas you have "hard water" which contains a lot of minerals. These can leave deposits on dishes that tend to bake on to surfaces as the dishes dry. In this case you add salt to your unit (again there is a reservoir to hold the salt).
In some cases a given detergent will react with glass, plastic, or ceramic depending again on mineral content and hard water. Changing your detergent can help.
Hope this helps, please rate if it helps get you with direction.
Mar 22, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher leaves film, smelly water
You need to use something with citric acid too try and clean out the calcium deposits inside dishwasher, you can get cleaner at the store or run a can of frozen orange juice thru it or a small bottle of apple cider vinegar. Do this with no dishes inside.
Jul 14, 2008 | Whirlpool 24 in. DU900PCD Built-in...
Bosch dishwasher SHU66C02UC
You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dw is still running the drain pump, then with a wooden spoon raise the red plastice stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dw start filling, then run cooking oil thru the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) thru the dishwasher to remove this.
Jan 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
473 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
