Question about Maytag Washing Machines
Have a maytag neptune washer approximately 5 years old, clothes come out stinking like sour milk, have tried bleach and vinegar and it continues to leave clothes stinking
  • 868 Answers
Start leaving the door open from now on.
Posted on May 31, 2008
  • Archie Ferrarini
    Archie Ferrarini Jun 01, 2008
    What it does is stops/prevents the mold&mildew from forming.
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
My 10+ year old Maytag Neptune washer has standing water behind the drum after the spin cycle
Griffin is correct but, I took it one step further and removed the front cover and rubber gasket and used a long thin brush after spraying white vinegar with a spray bottle and cleaned all the **** from around the drum. I use white vinegar with clothes once in a while to keep the drum free of built up soap and softner.Its a little work but trust me when you see all the stuff on the drum you will understand why the machine stinks. I also leave my soap tray door open all the time to allow air inside.
Oct 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
Smelly clothes
Maytag had a big problem with the rubber boot in the front of the washer.They redesigned it to drain better so water would not remain in the bottom and get moldy smelling.Open the door and look down in the boot with a flashlight.Make sure if there are drain holes in the bottom that they are clear and not clogged with soape or lint.Put a couple of old towels in the machine and a little soap and twice as much clorine bleach as normal and run a cycle.It should help.It is also good to leave the door opened between washes if possible.
Jun 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have sour mildew smell problem with my clothes
Look inside the door to the gray rubber ring gasket thingy. Pull apart the sides and look in. Betcha a dollar to a donut there's mold in there. It's a gross, nasty problem whirlpool customer service doesn't give a damn about.That's where water sets after wash cycles. There are tablets call "Affresh" which can be run with hot water for a cycle to attempt to clean out the mold/mildew. Not cheap, not fair, and probably will only be a start to a maintenance type cure if you've had the washer for awhile. May take some manual labor with bleach as well. NOT a sanitary washer. This is an unbelieveable problem with a washer. Piece of ****.
Aug 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer stinks like mildew!
i understand exactly...never heard of cascade ..the slug is to much what you have to decide which is more cost effective,,having a technician come out and taking tub apart for a manuel cleaning and scrb break down or purchasing new one..but i always tell my customers bleach every other month with hot wash cold rinse,,now i do have one last tip..try CLR..
Jan 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag front loader washing machine. Mould
How old is the washer? Did you try straight bleach on a towel and placed over the "mold" spot for about 5 minutes, be sure to wear gloves. Then scrub with a small brush being careful not to splatter bleach on yourself and rinse well. May need to replace the seal. I always leave the door cracked open after every use to "dry" out the inside and the boot. I also leave the drawer pulled out when not in use for that area to dry out as well. I have never had mold on the door seal of my Neptune washers, only the water holes above the dispenser drawer.
Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Detergent goes where?
3 - Select Cycle
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Neptune washer detergent department that is on the lid
use vinegar in cleaning it! soap, as it is made of mostly soda dissolves in vinegar.
also vinegar helps remove bad smell on the machine cause by residue dirt from clothes.
Feb 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
