Question about Belling Fusion 136 Electric Kitchen Range
Belling cookcentre 130wgr electric range
Ive lost the ability to regulat heat output on 3 out of 4 of the ceramic hob rings(one went at a time) such that they have to be all on or off.Please can you advise?
kind regards
Richard
2 Suggested Answers
SOURCE: hob regulator wiring
OK, they are wired so that the two elements are switched in and out, to form, a single, a dual but in series, and a dual, but in parallel. like this Low, ONE, Element ONLY, The Other is out of circuit. Med, TWO elements are connected using the switch, in SERIES with each other. High, you switch TWO elements in PARALLEL. Simply meter the switch out to do that when each position is turned. Just think of it like, It's just two resistors, wired up. single, series, & parallel.
Posted on Apr 19, 2010
We have a Sterling 1100E induction hob and have random problems with the hob not working at all, and tonight it just sits there in darkness but peeping constantly. The 2 ceramic rings work but not the
Some times the pots that you may be using are not designed for use in induction cooking. If you are, It might be the size of pot. The peeping sound might be the cook top looking for the pot. But when all else fails. Turn the stove off at the Breaker count to 12. Turn back on. Reboot. Hope one of these work.
Apr 14, 2013 | Stoves Sterling 1100E Stainless Steel...
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
Hob regulator wiring
Apr 19, 2010 | Belling CookCenter 151 Dual Fuel (Electric...
My De Deitrich induction hob wont heat up.
It is OK. The voltage was the problem. As soon as we went on to proper power again the hob worked normally.
Jan 10, 2010 | Kitchen Ranges
The fan oven does not heat up, though the fan seems to be working OK. Any ideas, please? It's a Belling Cookcentre Evolution with electric ovens
If the fan runs and the temperature light comes on but no heat then you will need to replace the fan element.
Jul 29, 2009 | Kitchen Ranges
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Belling Fusion 136 Electric Kitchen Range Logo
59 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
