Question about Mitsubishi VS-50705 50" Rear Projection Television
Mitsubishi VS-50va2 50 in. projection tv
The display reads tuner out. No sound or video. It is connected to regular cable tv. Can anyone help?
  • 29 Answers
You need go to set up andjustment mode and change the option of HOME THEATER to OFF position.
Posted on Jun 14, 2008
After big storm the tv only shows small picture in upper right corner. Will not allow to go to full screen. VS-45603
You are in pip mode, and if itwill not let show on regular mode, then your tuner is out,and youcan bypass it and go directly into the video input with RCA cables from your recieever,and put your set in video mode,better picture, and save you 500 dollars on a new tuner.
Jul 07, 2011 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-55609: No video/audio - just static
You are on the right track. If you cannot see a picture on either antanna A or B then the tuner is suspect.
You may try hooking the cable straight into the TV if you are using a cable box, if not then you should be getting a picture when your other video devices are turned off.
The fact that you get a picture on video tells me that the AV circuits are fine.
Thanks
asnowman
Jul 25, 2010 | Mitsubishi WS-55809 55" Rear Projection...
The tv acts like the cable has gone out even though it has not. on my mitshubishi rear projection 52 in
do you have the yellow video and red and white audio rca cables ?
it will give you a better picture than the coax connection.
but the tv tuner may be going , so using the rca jacks would eliminate the tuner, but finding out which tuner is bad ( cable box if using one or the tv tuner)should be checked with another tv to see if it also happends to that tv , if it does not then the other tv tuner is bad and needs to be replaced
Apr 18, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Scrambled picture mitsubishi VS-60805
Hello deltamech,
Are you using your component video cables? if you are check to see if you are using the correct inputs. Look at the babck of your TV and see if the RGB (Lettering) matches with the box you are connecting to. What I am talking about is the YP(b)P(r) vs the YC(b)C(r) they are incompatable with each other.
Check that and if that is the case either match the two proper RGBs up or use another interface.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 25, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-5003R Tuner Out
the tuner is where the cable hooks up on the back of the tv.its out and needs replaced.thats what the message means
Jan 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Mitsubishi rear projection tv
you have a problem on the chassis. either the FMT, DM, or the terminal board have gone bad. the quickest most effective way to repair would be to repair the chassis. check out www.tv-techs.com
Dec 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hi, I connected internet cable (was just experimenting whether cox internet cable will get tv channel signal or not) to the antenna port of my mitsubishi 50" projection tv and tv's display turned off after...
LOL!!!!!!!!, your tuner is now faulty and maybe your Microprocessor as well, you will have to take it to a repairer this something you wont be able to solve sorry ......
Dec 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Sound no picture
make sure all cables are connected properly and that you are on the right mode for your tv to display what you want. if no display and all cables are checked then tv needs to be serviced or replaced.
Aug 03, 2008 | Mitsubishi VS-50605 50" Rear Projection...
No Picture on Mitsubishi v45605 rear projection tv
If it works the way you have it setup now, leave that way. Plug all your video sources to the denon if possible and leave it that way.
If the denon has the feature to change channels like a cable converter then you can use it or if you still have a VCR you can also use it as a tuner just to tune the cable channels and use the audio/video outputs from it to the TV or denon receiver.
The tuner might not even be available anymore and if it's, is expensive.
Good Luck.
May 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs 45605 no picture
yes if the tuner is out and you want to save some money then running an external set top box or your denon are fine. more often than not you will also have better picture quality.
May 23, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
260 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
