Question about Rancilio Silvia Espresso Machine
I bought a used machine. I am not getting really strong, good espresso. How can I do some service checks?
  • 22 Answers
Many factors are involved here. Start with checking your grind, tamp, freshness and quality of the coffee, degree of roast.
www.kaldi.com
Posted on Jan 23, 2011
I Just bought a Saeco Intelia Focus espresso machine. I made coffe with 3 different coffe brands. Very good ones. And I became very disapointed when I try the results. Every time the espresso was way too...
Use less coffe , you are using too much , reduce the amout you are using . Presto . Also use homogenized milk , not skim , or fat free . Also use the water vapour to heat the cup before you make coffe , capuchino , caffe-latte, mocachino , espresso etc .
Oct 28, 2013 | Saeco Intelia Focus Automatic Espresso...
Should i go for an Espresso machine or coffee maker?
I can't really start my day without my espresso, so I'd say go with the espresso machine! I need my strong, black coffee fix every morning. But then again, it's a question of what you like. If you prefer different kinds of coffee every morning, buying a coffee maker might be the best way to go. I use the Gaggia Espresso Pure Semi-Automatic that I bought off Daily Cuppa Coffee for my espresso, in case you were wondering. They offer a wide range of both espresso machines and coffee makers; you can browse through them at www.dailycuppacoffee.com and select the one you like.
Jun 06, 2013 | Cuisinart DCC Coffee Makers & Espresso...
I purchased the espresso maker above. My problem is the strength of the espresso brewed. It comes out strong at first, but by the end of the dripping it turns watery. By the time the dripping stops the...
to have a good espresso depends from many factors, first of all is the coffe blend, the grind, then water quality, espresso maker pressure and temperature, and that is just the most important!...I think you can try with a REAL espresso blend with very thin grind, let the water flow without filter, then when the light switch on put the filter, you can also try to warm first for steam and after commute to make espresso and wait for right temperature. Finally you will obtain a discreete espresso, never as in the professional machines!...otherwise you have to invest such 2000 euros for a professional good coffe machine
Aug 22, 2010 | Ariete Cafe Retro Espresso Machine
How many oz of expresso when making a 2 cup with the machine in a measuring glass . i bought two measure shot glass to make a perfect cup of latte. i know it says 24 seconds
For every cup of espresso we mean about 25cc to 30 cc and you have to use from 7 to 8 gr of groud coffee per cup according to the coffee blend and how strong you wand the aroma of your coffee. The running time for making either one cup or two cup with apropriate filter is about 24 to 30 sec maximum.
Good luck
Apr 18, 2010 | Breville ESP8XL Espresso Machine
Gaggia Evolution Filtering Weak Coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jan 03, 2009 | Gaggia Evolution Espresso Machine
Water and frother are weak
Dec 17, 2008 | Saeco Royal Digital Plus Coffee...
Coffee not strong enough
I had a problem like this with my first proper Gaggia. Cutting a long story short I found that the coffee I was using wasn't ground finely enough. The Illy stuff that comes in cans was ok, but pretty much everything else preground (incuding Lavazza!) was too coarse.
Sidestep the problem by getting yourslef a Rancilio Rocky grinder then you can adjust the grind in TINY increments for your perfect coffee moment...
Sep 24, 2008 | Rancilio Silvia Espresso Machine
our waste coffee is it consistant like stay in 1 round piece or loose lock at it if it lock like it was fine grind i suspect that our machine dont grind fine enough our coffee should have that lovely brownish cream on top maybe grinder need ajustment it wasnt done properly at the compagny and you said you adjusted the dial in the grinder but what about the quatity of coffee look in our manuel fine grounded coffee good quatity of coffee our suppose to get that perfect expresso i think ajust our dial for quatity of coffee thanks for using fixya pierre
Feb 09, 2008 | Gaggia Titanium Espresso Machine
My coffee tastes weak
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with a bad burnt taste.
Dec 28, 2007 | Starbucks Barista Utopia
Wet Steam? Weak Espressos
Sep 11, 2007 | Saeco Vienna SuperAutomatica Coffee...
Rancilio Silvia Espresso Machine Logo
32 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
