Question about Lasko 2515 Tower Fan
Control panel circuit board is blown. Can I get a replacement board?
My power shows good but no picture
This is likely a blown power board with secondary capacitors blown and not the primary. If your power board shows green LED and no picture then there is no power really going to other boards.
Check the power board for blown caps. This can be an easy fix and low cost if you are handy with a soldering iron and can replace caps.
Apr 13, 2015 | Televison & Video
I have a Whirlpool ADP9000ix diswasher that will not power the front display/touch panel. Therefore cannot turn the dishwasher on. I have checked the circuit control panel. And power is getting to it....
If your Whirlpools over there are like the older ones here in the U.S., you may find that there is a thermal fuse mounted just above the circuit board. If there is one, turn off the power to the unit, pull off the 2 wires connected to it and check it for continuity with a multimeter. If that fuse is blown, nothing works as it controls all power to the unit. Replacement fuse kits (at least here in the U.S.) are readily available on ebay for a fraction of the price that an appliance parts store would want. By looking on ebay for "Whirlpool dishwasher fuse" you can see what the fuse assembly looks like, and if identical to yours, purchase one. If you do buy one, follow the installation instructions exactly by using the supplied wires on the new fuse and the screw terminal block to make the connections. If you don't use the new wiring and connection block and simply plug the new fuse to the old connectors, it will simply blow again in a short time.
Jun 07, 2014 | Dishwashers
Maytag epic dryer
Without seeing dryer and checking it , best guess could be main control board problem
Dec 08, 2013 | Dryers
Start button wont respond.Ultra wash s/n 15801805808
Check to see if the electrical breaker is working for that circuit. Next check the outlet that the machine is plugged into (115Vac). If all is, so far, copescetic, Turn off the breaker and pull the control panel. Test the "button" with a multimeter. If it is solid state, turn the breaker back on and CAREFULLY test to see if there is voltage coming into the panel. If not, look for a blown fuse. If no blown fuse and voltage is there, replace control board! Good luck!
Dec 27, 2012 | Dishwashers
SAMSUNG SP-50L7HX DEAD FUSE BLOWN BLACK OBVIOUS SHORT CIRCUIT ANYONE KNOW ANYTHING IF BOARD REPAIRABLE O
Try shopjimmy.com who carries almost all the Samsung boards--if fuse right where power cord does come in trouble is right there.
Aug 30, 2012 | Samsung Televison & Video
My Kenmore 9114742592 Wall Oven does not work. The display is blank and the circuit breaker is not tripped. What can I check for?
HI, check the junction box for separated power cord wires. replace the junction point if the wires are separated and not connected to the oven properly. replace the cord as well in this case.
Now, if the power cord is ok and, the junction is connected properly, this will confirm that the control or, clock has failed. replace the clock or, oven control board in this case.
Jul 10, 2009 | Kenmore Ovens
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Fedders won't turn on
you probably blew the fuse behind the control panel. remove the front cover and then remove the control panel (usually a few screws). There should be a glass fuse attached to the circuit board. If its blown then just replace it and you're good to go.
Aug 17, 2008 | Fedders Q Chassis A6Q10F2A Air Conditioner
Lasko 2515 Tower Fan Logo
29 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
