Question about Belling XOU482 Electric Double Oven
I have a Belling Formula Oven, model 168/169 I beleive. The clock works but the oven, the fan and the light does not work today. Any ideas what I should check? I measured the Element it is 24 Ohms.
barkencoa
  • 3463 Answers
SOURCE: Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Posted on Dec 13, 2008
  • 157 Answers
SOURCE: belling oven fan works without heating the oven???
element
Posted on Jun 30, 2009
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
bozcro
  • 867 Answers
SOURCE: We've inherited a belling electric double oven.
seems the heating element burnt out, inspect it for small melted section, element needs replacing, about 25$ at hardware store
Posted on Aug 21, 2009
barkencoa
  • 3463 Answers
SOURCE: Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Thankyou.
Posted on Feb 02, 2010
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
Tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
Belling evolution 152 main oven stopped working and clock gone out.
Have you checked the power source to the oven? Has the cord come out of the wall plug? Has a circuit breaker tripped? Once the obvious things are checked and proven good will it be necessary to dig into the interior of the appliance.
Oct 14, 2014 | Ovens
My Belling XOU179 has stopped working. The grill still works but the oven does not heat up - any ideas? Also, can anyone tell me how old this model is? Frances
If it is a fan assisted oven and the fan is working o/k, then you need to replace the oven element. I think that your model is quite an old one going by the model number.
Thanks.
Nov 09, 2009 | Ovens
How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Mar 23, 2009 | Belling XOU174 Electric Single Oven
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Belling synergie oven - main oven won't come on.
hi
check the timmer clock is not in auto mode as this will stop the oven from turning on. if clock ok then fault could poss be the thermostat
hope this helps you
regards dan
Mar 03, 2009 | Belling XOU174 Electric Single Oven
Belling XOU482 Electric Double Oven Logo
104 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
