Question about Sport & Outdoor - Others
Instruction Manual for Slendertone Fortex Upper Body Exerciser
4 Suggested Answers
SOURCE: I want an instruction manual for the Chattanooga Deluxe Exerciser
Caution: The internal unit has grease, gears and cables so be careful.
To change the batteries, the blue 'read out' display plate lifts off and on the underside is the battery receiver. Facing the blue display, I simply inserted my fingernails under the top of the face plate and pulled. It lifted off fairly easily but does offer some resistance. I'm sure a flat bladed tool such as a screw driver would also work.
Note: There should be a cable/wire going from the internal mechanism to the plate. If it is not connected to the face plate, you will not get a readout. Use caution when reaching inside the unit and do not turn the pedals. Look inside the unit for a loose black cable/wire with a white stripe. On the end of that wire is a single prong plug that inserts into the backside of the display plate. My plug's receiver had threads so it may be that some cables/wires will have a screw-on type connection.
My instruction manual (leaflet) did not show how to change batteries or hook up the interior cable/wire. I could ot find the product or related instructions on the companies website but here is the information:
www.chattgroup.com
Chattanooga Group, Inc.
4717 Adams Road
PO Box 489
Hixson, TN 37343
U.S.A.
Posted on Dec 02, 2010
  • 5161 Answers
SOURCE: Do you have an instruction manual for the
Try this URL: http://www.chattgroup.com/product.asp?pr=508&ln=1&cn=5&loc=1 . The User's Manual (PDF) is on the right side of the page under Product Downloads.
I hope this helps.
Posted on Mar 10, 2011
Raypena
  • 41 Answers
SOURCE: I am looking for an exercise manual for body
HERE IS ONE
BEST OF LUCK.
Posted on May 31, 2011
I want to watch the get started video on The Flex Belt, How to get started.
Flex Belt - YouTube
? 8:16
https://www.youtube.com/watch?v=gBYvxDeb5VY
Jun 28, 2013 - Uploaded by flexbeltabbelt
We've created helpful videos that will walk you through the easy set-up process. It is very simple to set up The Flex Belt and only takes a couple of minutes... ... tips for awesome results and help you with any questions you may have. ... Getting Started with your Flex Belt - Duration: 8:08. by flexbeltabbelt ...
The Flex Belt video review - YouTube
Dec 08, 2015 | Slendertone Flex Pro Abdominal Muscle...
Slendertone keeps beeping
the beeping its becouse there is no contact between the pads and the skin (1), or the cables and the pads (2), or the cables and the controller (3).
what the manufacturer says:
try to change the pads by new ones
i did that, but still not working.
what i do:
i had the second problem, but i fix it, i cut the cloth in the back part of the pin (not in the front of the pin), and i discover that the cable that is attached to the pin was cut, i remove the the pin, then i replaced with a bolt, i attch the cable to the bolt and thats all.
i'm using it right now and its works great.
i answer on another post similar to this one, a put a link to my google account where you can see pictures of what i did.
thums up! thank you!
Dec 28, 2013 | Slendertone Fortex
My slendertone wont turn on. it did and i turned it off!! and when i went to turn it back on it wouldnt turn back on and i have changed the baterys!!!
I've had the exact same problem! I turned it on, and the lights went on then I looked at the next step in the manual and thirty seconds later max when I looked at the belt it had turned off! And now it won't turn on again! I've changed tha batteries and it still won't work! Please let me know if you find a solution!
Aug 13, 2011 | Slendertone Fortex
Bought Slendertone Start but lost instructions so dont how to use.Would like the instructions for slendertone start
Manuals for the various Slendertone products can be found here:
https://www.slendertoneusa.com/t-manuals.aspx
There does not seem to be a manual specifically designated for 'Slendertone Start'; is that a specific product or a program for using one or more of the Sendertone products?
May 21, 2011 | Health & Beauty
Do you have an instruction manual for the Chattanooga Delux pedal exerciser
I hope this helps.
Mar 10, 2011 | Chattanooga Group Deluxe Exerciser
My slendertone belt keeps beeping with a triangle next to it. I can't turn up the intensity and it won't vibrate but I'm not sure why. What's the problem?
I just replaced new pads but that triangle still appear. Can't really do anything with the belt right now. Really frustrating.
Feb 18, 2011 | Slendertone Fortex
www.chattgroup.com
4717 Adams Road
PO Box 489
Hixson, TN 37343
U.S.A.
May 29, 2010 | Chattanooga Group Deluxe Exerciser
The LCD readout and audio tones on my Fortex unit have stopped working. Tried new batteries, checked the wires - all look ok, but the LCD panels are black (not the usual grey colour)
First pull the battery's out then insert them correctly,if they are in correctly then the upper console has failed and needs to be replaced.
May 27, 2010 | Slendertone Fortex
How do you work the Slendertone Belt? I lost the
hold it in front of you comfortably and pull outward (its pretty straight forward)
Jan 13, 2010 | Slendertone Fortex
Sport & Outdoor - Others Logo
503 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
