Question about GE DPSB613EDWW Electric Dryer
My dryer drum will not turn - GE DPSB613EDWW Electric Dryer
  • GE Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 12, 2010
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
Are dryer turns on but will not turn inside
you may have a broken drum belt, you'll need to replace it in order for the drum to turn.
Oct 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Kenmore Dryer Mod.76990100...shreiking noise when drum turns??
hi,
Dryer Is Noisy
1) Some noises are caused by objects bouncing around inside the drum. Scour the interior of the drum for loose objects.
2) If you cannot find any loose objects inside the drum, the noise may be caused by a defective part, such as a worn or defective drum belt, idler pulley, support rollers, glides, or worn motor bearings. It’s best to call an appliance repair service to replace these parts.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Dryer Motor won't always start Model FSE747GES
Too much drag on the Drum. Try lubricating the rollers that the drum turns on. Check the belt tensioner pully...lubricate that as necessary. If Drum still turns very hard after this then take belt off of motor and try turning drum. If drum turns easily then replace motor.
Nov 24, 2008 | Frigidaire FDE336RE Dryer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
GE DPSB613EDWW Electric Dryer Logo
85 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
