Question about Garmin nuvi 750 GPS Receiver
Low battery display comes on when it is turned on then it shuts off its self
    Problem Solver:
  • 7 Answers
If this occurs when running on battery power, then it sounds like you just have a dead/bad battery.
If your GPS works fine when connected to a power source, then leave your GPS plugged in to a power source over-night, and if you still have this problem...
You can check to see if your device was included in a recent battery-related recall here:
https://my.garmin.com/rma/recallLanding.faces
If your unit is not included in the recall and you are (or a friend is) handy, you can buy a replacement on the net and replace it yourself for around $25 (US Dollars):
http://vimeo.com/8387716
(There are other sources for the battery, I do know if the linked company is trustworthy.)
I'm not sure what Garmin charges for this type of service?
Posted on Oct 25, 2010
My battery light has been coming on and off for a couple of weeks now and saying "Service Battery Charging System".
Have your charging system tested. The battery light is turned on when there is a charging system problem causing an over/under charge condition. You may possibly have an alternator problem. If the battery is not being charged properly, the computer will start shutting down electrical components for protection and to keep enough voltage supply to enable the vehicle to continue running
Jan 27, 2016 | Cars & Trucks
Low battery
see the chart and test it. God bless you
Jul 31, 2013 | Mercury Monterey Cars & Trucks
Battery low indicator comes on even after new battery installed
I also have this problem. I put freshly recharged batteries in the DX3900 and the camera starts to turn on and reads the memory card (the green LED blinks) and then I notice that the in CAPTURE mode the lens does not extend out of the body housing. The top display shows a flashing low battery warning and after approx. 15 seconds, the camera shuts off with no function.
I have determined that the camera appears to have changed its low battery sense level as I have verified that the batteries are indeed fully charged by using a volt meter. If I have the camera in a warm environment, and do not have the LCD display on (removes a major power drain) the camera can be made to work for a short while. If I select the LCD to turn on, the extra drain seems to cause the camera's battery monitor to think that the battery voltage is too low and the camera shut down. I have yet to resolve this issue.
Aug 18, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
My Garmin turns on and shuts its self off.
But it might have a very low charge or a bad battery (despite being connected to Dc) recharge the battery from AC or replace the battery
Jul 24, 2009 | Garmin nuvi 255W GPS Receiver
Air Conditioning system 97 deville
Look for a high side pressure sensor. It sounds like something is tripping an A/C code.
Mar 11, 2009 | 1996 Cadillac DeVille
Low battery display
i had a similar problem...my lense woudnt go back in either, but it kept saying low battery and bleeping. I realised that my lense was stuck skwint, and that was what was causing the problem, once i straigtend up my lense it folded bak into the camera and worked fine wen i turned my camera on :D
May 06, 2008 | Samsung Digimax D53 Digital Camera
Displays low battery then shuts off
Same problem. Fresh batteries, fresh batteries and plugged in and just plugged in.
Jan 21, 2008 | Sirius SUBX1 Universal Plug and Play Boom...
New Batterys and camera indicates batterys low then shuts off.
Did the batteries come with the camera? If not, they might not be a high enough mah rating. Some batteries, even though brand new, may not be strong enough to power a camera.
Dec 06, 2007 | Kodak EasyShare CX7530 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Garmin nuvi 750 GPS Receiver Logo
108 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
