Question about Viking VGIC485-6G Gas Kitchen Range
Viking range VGIC3074BSS
The oven doesn't always light. Sometimes the ignitor sparks 2 or three times and it will light, sometimes it starts with a small BOOM, sometimes it won't start. This has been going in one form or another since I bought the stove about a year ago. I tryed adjusting the air shutter on the burner tube and the postion of the spark ignitor relative to the burning tube by bending the probe slightly. Any suggestions?
Joe G.
  • JoeGunz Jun 02, 2008
    Thanks for the info. I called a repair guy.
    Joe G.
freetek
  • 5568 Answers
SOURCE: Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Posted on Jun 19, 2008
SOURCE: Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Posted on Oct 02, 2008
SOURCE: burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Posted on Dec 14, 2008
  • 44 Answers
SOURCE: Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Posted on Mar 19, 2010
oldTech2332
  • 2341 Answers
SOURCE: I have a Viking vgic365-4G gas range. I recently
their is one of two things causing that,
1) the switch that supplies power to the spark module when the burner is turned on is bad...its located on the shaft of the burner valve thier is one switch for each knob so counting the oven and the burners their is 5 (the oven is different from the surface burners) to check those switches what needs to be done is remove the knobs then the face panel so ya can get to the knobs.
No is where is gets a bit complcated if ya dont follow all procedures....the knob must turned on to check so gas will be flowing and ya must light the gas using a match or raw gas will eneter the kitchen...or if possible temporarly turn off gas supply to the unit.also POWER MUST BE DISCONNECTED and then with power off and the burner lit manually once turned on ya would need to check each switch to have continuity,if any of the switches does not have continuity when measured with a ohm meter that switch will be bad
2) the igniter is cracked so power is coming from spark module yet since its cracked power is jumping out before it gets the where it lights the burners.
GENE
Posted on Oct 02, 2011
My maytag mgr5729adw gas range oven omits a strong gas smell when attempting to preheat. Sometimes it heats sometimes it doesn't but use to get a small boom when igniting. Ignitor still glows oran
see the next steps and proceed with common sense: God bless you
Main Control / Oven Switch
The main control or oven switch may have failed. You will need to identify the wires from the switch/control that lead to the igniter that is clicking. These wires may pass through the spark module and change colors. Refer to the wiring diagram or tech sheet. If you have power leaving the switch/ control when in the off position replace the switch /control. Manual switches can be tested with an ohmeter.
Spark Module / Igniter Module
If your oven igniter keeps clicking the igniter module or spark module is the likely problem. First be sure the igniter is clean and the surrounding contact points are clean. Make sure power is off when cleaning. If the oven keeps clicking after it's cleaned and the oven switch / control checks good replace the spark module.
Jul 26, 2012 | Kitchen Ranges
Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
I have a Viking vgic365-4G gas range. I recently replaced the spark module, the ignitors for the oven and the griddle, and the spark ignitors for the burners. The problem I am having is only one of the...
GENE
Oct 02, 2011 | Viking VGIC365-4G Gas Range
Viking gas oven model # VGIC3656BSS, serial #022404-2919 takes FOREVER to preheat up. Sometimes in excess of 40 minutes. Been a problem for a while. Looks like flames at bottom do not increase when oven...
When increasing the temp. on a gas range the oven's burners do not increase flame size as the cooktop burners do. It just keeps the burner lighted for a longer amount of time.
First if you can see the burners do they light within about a min. or less. If no you probably have bad igniters which are not lighting the burners as quickly as they should or they are "opening up" (stops working) when they get too hot. In this case replacement of the igniters should solve the problem.
Second if it lights quickly but still takes a while to heat; you want to look at the burners to ensure that the flames are down both sides of the burner tube and not dancing around too much. If only part of the two sides of the burner tubes are lighted then a pluged orifice or burner tube is the most likely cause. Once cleaned it should work fine.
As with anything mechanical there are numurous possiblities for something not working correctly and above are the two most popular reasons that come to my mind.
May 17, 2011 | Viking VGRC485-6 Gas Kitchen Range
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Burner ignitor will not turn off after the burner lights Viking
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Mar 28, 2017 | Kitchen Ranges
Viking Range
I'm having a similar problem. I don't know the exact fix yet, I'm just starting to research. Check this link: http://www.applianceguru.com/forum1/1916.html
It sounds like the ignitors are suspect. This may be a weak component for Vikings. This link recommends a Maytag replacement part.
Dec 08, 2007 | Viking VGSC366-6B Gas Kitchen Range
Viking VGIC485-6G Gas Kitchen Range Logo
601 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
