Question about Carrier Heating & Cooling
What is the coolant used in a 1995 Carrier model 38TUA and how much longer will it be available?
  • Carrier Master
  • 43,501 Answers
That would be R-22 and it will be available for a few more years ....and... even after that there are direct replacement drop in refrigerants for the R-22.
However the price will be going up dramatically as time goes on...
BTW... check the name plate on the side for the refrigerant
heatman101
Posted on Oct 11, 2010
Do they carry a sin card what carrier
Hi all gsm phones will carry or accept any GSM sim card you can't use the phone without sim in it ...The phone will accept any carrier sim if it is unlocked one else if the phone is locked to any particular carrier then it wont accept any other carrier sim until you unlock it .You can easily unlock the phone through online providers like SimpleUnlocking.com here they are rendering network unlock code for all mobile models at reliable cost .You first check that whether the code is available for your mobile model ,country and network provider .If yes then pay for it and unlock your phone then freely use it with any carrier sim ...
Oct 24, 2014 | Cell Phones
What is the part number for a carrier bearing on 1995 chevy camaro
(a little late in responding - but maybe someone will need this info).
If you mean the carrier bearing on the driveshaft - then you must have a v6 model. I would advise to skip replacing it and instead purchase a 1pc shaft (no carrier bearing). The cb is located near a Hi-Speed CV Joint which make changing the carrier a little difficult.
A new replacement 1pc driveshaft costs about $225.00
The carrier bearing itself may run $40-$140. ( http://www.fortwayneclutch.com/index.php/driveshaft-parts/carrier-support-bearings/gm/1993-2002-chevy-camaro-v6-pontiac-firebird-v6-carrier-bearing-new-f-body-carrier-bearing-for-v6-models-pn-s-3r80-40.html ) - for reference...
You could also check a junk yard for a 1pc oem shaft (most shafts there are bent or have bad uj's and will cost $$ to have fixed )
>1994-2002 f-body models all have the same length from the seal of the transmission to the center of the uj @ the diff.
>when looking for an oem 1pc shaft you will find them in Steel and Aluminum. Slight differences in length when measuring center to center of the universal joints ( 40 7/8" - 40 1/2" ) - but the slip yokes vary in length, weighted / non-weighted..etc = this will make it appear the the shafts are different.
>>watch out for oem shafts with the weighted slip yoke from manual 6spd v8 models. This slip yoke may hit the trans/exhaust mount that is used on v6 models.!!
Jan 13, 2013 | 1995 Chevrolet Camaro
What coolant is best to use on a pt
Regular green looking and not a yellow color it is corrosive to the PT.
Aug 21, 2011 | 2002 Chrysler PT Cruiser
An air conditioning technician told me that my Carrier XCB183D (9 years old) needs to be replaced (not cooling sufficiently) but that model is no longer available. Is that true?
Thats very likely, they update and come up with more efficient units and discontinue the older models.
The compressor will lose effieciency over time.
Jul 28, 2011 | Carrier XHD183D Air Conditioner
Need manual to install on bike
Wow. My research shows an enormous number of people who bought this and it had no manual. Their website is seriously inadequate.
What I could find is this....
Bell Sports Inc 1-800-456-2355 manual #09598
41c14yesx4l._sl75_.jpgBrand: Bell
This item is no longer available
Model: 1002474
UPC: 035011005836
EAN: 0035011005836
ASIN: B000F934W2
Apr 30, 2011 | Bell Cocoon Child Carrier
What type of antifreeze coolant is required for 1995 intrepid
Your 3.3 or 3.5 V-6 came with the green original antifreeze...however all of my experiences recommend the new "Good for All Makes and Models" replacement antifreeze. It is designed to perform longer...:) Be sure to monitor your level for a couple of days...this system is vented by the overflow, and sometimes moves air around...this is common, just top off as necessary:)
Dec 09, 2010 | 1995 Dodge Intrepid
I can't find a grass catcher attachment for my Poulan/Weedeater walk behind model HD41486A. Help!
Hello, I did finally locate your model number in my Electrolux Home Products catalog, HOWEVER, the bag is no longer manufactured and as near as I can tell, there are no longer any available to purchase. You can still buy the frame and hard plastic top but no bag.
This is a 1995 model so this is not an uncommon thing.
I can look up the part numbers of the available items for you if you want them.
Sorry I could not present you with better news.
Chuck
Nov 04, 2009 | Poulan "Poulan" Push Mower
What coolant should i use for 04 3 series?
Vehicle: Fluid Type Specifications
Coolant
Coolant Type
Model: All, except E60
BMW Antifreeze/Coolant Part Number ............................................................................................................................................ 82 14 1 467 704
E60 vehicles only:
Lifetime coolant, routine replacement is no longer necessary
If you flush the system you can use any high quality coolant.
Nov 02, 2009 | 2004 BMW 3 Series
Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
71 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
