Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch SGS43C12 dishwasher fills with water as normal at start of programme, then you can hear a quiet 'click click' normally the cycle would start, but nothing happens. I can press reset and it drains the machine well. Have cleaned out filter and checked rotor arm for blockage all fine. thanks Pete
    President:
  • 1,140 Answers
Where does the clicking sound seem to be coming from? Start the machine and when it's filled with water, try to identify where the clicking noise is emanating from. I suggest putting you ear next to the programme selector and start/stop switch and see if you can hear it more loudly/clearly.
Sounds like a faulty control module to me. Try the above and report back . . .
Posted on Oct 12, 2010
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Bosch Classix SGS43C12 dishwasher programs not working & dispenser drawer not opening
The control board on this model is know to have issues with dry solder joints, If you are handy with a soldering iron you can fix it quite easily.
Mar 04, 2012 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Hi, Dishwasher problem: When a programme starts, the machine fills with water then stops and the "check water" light comes on. To empty the machine, I used the reset programme which does empty the...
You will need to check the inlet valve and the water level pressure switch. It can also be a low pressure in the pump that is giving out the signal for the control board to shut off.
So first of all check the water line throughly to confirm.
Oct 02, 2010 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not filling with water when switched on
Can you hear a low humming noise coming from the dishwasher when you start it?
Oct 01, 2010 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher fills and empties water but doesnt run any programm
Hello, welcome to FixYa. Can you elaborate on the actions which take place ? Does it fill and just sit idle until eventually drain or do you cancel the cycle manually to initiate the draining ? I should be able to help you with some more details. I will watch for your reply. macmarkus :)
Jun 24, 2010 | Bosch 24 in. SGS43C12 Classixx...
SHE45M05UC
the problem is the float switch is stuck
Dec 11, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
if no drain, then no cycle. problem is probably that draining is not taking place. check the following: if plumbed in under the sink, remove drain hose from spigot and check no blockage. start any program - all programs start with drain. listen carefully for a low humming noise. if you hear this, it means you have something stuck in the pump impellor - bit of bone, cocktail stick etc. get back to me if you like with what you find
Jun 26, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
563 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
