Question about Refrigerators
My refrigerator seems to not be cooling, but the freezer is working fine. I don't know that narrows the problem done to just one thing. im guessing not. Do you have any suggetions?
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101.
Posted on Oct 12, 2010
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
I've had a Samsung fridge for 6-7 years, it's a small/medium fridge/freezer with the freezer at the top (sorry, don;t have the size handy). The freezer works fine, however the fridge no longer makes...
heatman101
Sep 27, 2010 | Samsung Refrigerators
My Fisher and Paykel upper refigerator is not working. The lower freezer seems fine. Wha can be done to fix?
heatman101
Sep 20, 2010 | Fisher and Paykel E522BLXU
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | Refrigerators
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
Whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Huuum
Please remember to leave a rating for me!
Oct 08, 2008 | GE Hotpoint Top-Freezer Refrigerator
Refrigerator not working
Hello bobbie50,
Welcome to Fixya,
You said, After making a louder than usual grumbling noise several times today, my refrigerator is no longer cold (freezer too). Please tell me I don;t have to buy a new one. my refrigerator is not working properly. The freezer keep thing cool but will not freeze. the bottom part does a little cooling ,but not like it should.
Help me with a little info.
What is the model # and the year or age of your fridge?
Let me know right away. I'm here for you!
Huuum
Aug 04, 2008 | GE Hotpoint Top-Freezer Refrigerator
GE GSS 25QF Side by side Refrigerator
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 14, 2008 | GE GSS20IEP Side by Side Refrigerator
Cool but not Cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirpool refrigerator, freezer fine, refrigerator warm
my suggestion give it up for the dead
Feb 23, 2008 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
