Question about Kenmore Elite HE5t Washer
Hi, I have a Kenmore elite model #11047789700, and it's presents the error codes SUD, and then F35 or in other instances F20. I check the hoses, drain pump and its seems ok. Thanks for your help
  • andy_gtr Oct 11, 2010
    Thanks, I would check and the pump and filter looks ok. I will buy the pressure switch. If the problems persist I contact you later.
    Regards
    Yes, thats confirm what I suspect.
    President:
  • 1,554 Answers
It sounds like you are having trouble with your drain pump or the pressure switch since both error codes are related. Check the drain pump particularly the impeller and the pump filter. Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, turn the pump filter knob counterclockwise to remove and clean it. Reach in the pumpm impeller with your finger and turn it. Strings can get through the filter then wrap around the impeller and restrict it. Replace the pump is the impeller is broken or restricted for no apparent reason.
Check the connection of the pressure hose both at the tub and the pressure switch itself. Blow air through the pressure hose going to the tub and the pressure switch. Replace the pressure switch it no issue is found with the pressure hose and its connections.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 11, 2010
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore HE5t code SUD and F35 keep coming up. i opened front bottom cover and cleaned out trap. tried running a clean cycle and code SUD came up again and the the F35 what could it be now???
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Kenmore Elite HE5t Washer
Kenmore elite he3t stream showing error code sud then f35
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 01, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore elite washer he3t model 110.4674 and the error code F35 keeps coming up. We did clear out the bottom drain pump, which had a lot of debris including toys, socks...etc. How can I clear the...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^##
Jun 10, 2010 | Kenmore Elite HE5t Washer
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
399 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
