Question about Linksys Wireless-G WRT54G Router
Cannot connect to the internet not geting connection signal
  • 1 more comment
  • victordc Jun 01, 2008
    wrt54g
  • nanu1 Jun 01, 2008
    trying to replace a Siemens Gigaset se567 with a Linksy model wrt54g
    followed the steps on the cd & still can't internet connection.
    Hooked up the Siemens & got connected to the internet.
  • Anonymous Jan 09, 2009
    HP cannot get a wireless connection and does not show area networks
Worked like a charm! Thanks a lot arvindB!
Posted on Nov 18, 2008
  • 34 Answers
JUst follow these steps and the issue will be resolved....
U dint specify that whether u r using the cable Internet or DSL!!
Steps for Cable internet...
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
STEPS FOR WIRELESS CONFIGURATION
6,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a
user name and password..leave the user name blank and the password will be admin.
7,
U can see the option WIRELESS in the black bar..click on wireless..
Wireless network mode should be "Mixed".wireless network name can be ur first name or anyother name.select the channel as 11 and the SSid broad cast should be Enabled.click on save settings.it will say like "Settings are successful"click continue.
8,to set the password for ur wireless network...below wireless tab in the black bar..u will find a blue bar which says "wireless security".click on "wireless security". Security mode should be "WEP"..Default transmit key should be 1.wep encryption should be 64 bits..passphrase should be empty..in the key 1 box enter ur 10 digit telephone number(ur telephone number will be ur password for the wireless connection)click save settings and continue..
9,
now in the laptop check whether the wireless switch is turned on...u can find ur wireless signal..while connecting it will prompt for a password.enter ur telephone number there..
u will be connected to the internet..
NOTE:FOR THE INITIAL CONFIGURATION U NEED TO CONNECT THE LAPTOP OR DESKTOP DIRECTLY TO THE ROUTER WITH THE HELP OF THE ETHERNET CABLE
ALL THE BEST!!!!!!!!try it and post ur feedback
Posted on Jun 03, 2008
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
My laptop won't connect to the internet via wireless even though it sys it is connected to my wireless router
Need more info.
Do you know what type of wireless security you are using?
The first place to check to see if you are "really" connected is to click start, run, type "ipconfig" (no quotes) and see what IP address you have. If you have anything that starts with 169.xxx.xxx.xxx , you are not really connected.
Mar 01, 2011 | Computers & Internet
Not geting any signal
since you have not stated which signal the computer or internet
i will have to make a guess
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
ring your ISP internet sevice provider get them to check your modem for internet access online
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
hope this helps
Jan 08, 2011 | Computers & Internet
I get messages that Internet is not responding ??
1. Please check the DNS is present in your router or not.
2. Please check your router is connected to internet cable.
3. Please check your internet cable is connected to your router's internet port only.
4. please check your compuetr is geting IP address or not
Mar 13, 2010 | NetGear WGT624 Wireless Router
Only get signal now and agian
check your phone's compatibility(signal) with your service provider's signal..generally be sure you are using a gsm connection for gsm phone...try resetting your phone as per the references in the instruction book
May 22, 2009 | Sanyo SCP-7050 Cellular Phone
Good signal no internet browsing on g-102 wireless adapter
Not sure what OS you are usin but if it is XP try this -
1. Disable Windows Firewall
2. In Internet Options Control Panel go to the connection tab and then the LAN Settings where you can uncheck the "Automatically detect settings" button.
3. If you have any third party software, I would get rid of this and ensure that the"Windows Zero Configuration" in the Services menu is set to "Automatic" and the status is started.
Interestingly, Anti Virus programs sometimes interfere with wireless set up - you could see if it helps by disabling it whilst configuring your wireless. It might also be worth trying to connect without any encryption code & see if that will connect - you can then sort out the encryption. Hope this helps!
Mar 13, 2009 | Computers & Internet
Im trying to get the internet on my psp but keep geting a dns error code 80410418 can u plz help
You have to know all the internet settings of the connection your are trying to use...
See if this connection are using some security Protocols...
try to folow all the Psp connection wizard and set all the configuration correctly....
Good Luck!
Dec 09, 2008 | Video Game Consoles & Games
JVC HR-D337MS Multisystem VCR - NO SIGNAL The only information I could find on the internet was it was worth $450.00 in 1991. i hooked up the RF out to RF on the TV in. Pushed play on the VCR. No signal....
Connect RF out of VCR to Antenna IN of TV. There should be a Test Signal switch at rear of VCR. Push it to ON. JVC VCRs generally generate a RF signal in the UHF band, around channel 36. Scan all channels on your TV, you should gete a Test signal of 2 parrallel black bars around channel 36. That is the Channel on which you can view tapes. Switch off 'Test signal' at rear of VCR, and press play. you should be able to watch your tape.
Jul 14, 2008 | Televison & Video
Limited or no connectivity... For a week
i think i have an idea for you as mine did the exact same thing..
do you have another like internet box as i have an older NTL box.. anyways
if you do try unplugging the 4 wires in the back of the box or whatever and then you put the ethernet into the back of the computer and just leave the power on
May 22, 2008 | NetGear WGR614 Wireless Router
Linksys Wireless-G WRT54G Router Logo
195 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
