Question about Daewoo Refrigerators
I need the bottom shelve for the Daewoo FRG1850BES. Can anybody help their 1800 number is disconnected not sure who that can be.
Fresh food door will not close/seal
Check to see if one of your door shelves is bigger (sticks out more into the fridge) than the other ones. If it is, theses shelves can cause door closing problems. Try removing the shelf from the door and closing it again. If this shelf is the problem, call subzero at 1800 222 7820 and give them your model and serial number, and they will send you a new standard depth shelf to replace the deeper shelf at no charge, these shelves caused a lot of door closing problems when they came out. Hope this helps!
Sep 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Hi I bought a iphone 4 clone in china. I'm not sure about the model: the label inside states: Model F8+. It is a dual SIM, GSM/GPRS GSM quad band 850/900/1800/1900. The phine worked in china with my...
Ciao! Go to settings- SIM card settings and set both SIM cards as active, usually it helps. If not, reset the phone settings, the code is 1122. Spero che ti risolva la tua problema.
May 15, 2011 | Apple Cell Phones
I need a radio code for my Leganza.
Remove the radio from the dash, use a wooden stick so as not to crack the plastic when you GENTLY pry off the plastic. Two screws and radio slides out. No need to disconnect wires. Retrieve radio serial number, (white tag with black numbers on mine). Get this and your VIN number and send email to DaewooUSA. They will send you radio code. (nice folks, very helpful) Disconnect the POSITIVE battery cable under the hood. Wait a minute and reconnect. Your radio will now blink "coDe" Enter the number provided by Daewoo.
Nov 13, 2010 | 2000 Daewoo Leganza
The freezer shelves in my ge Dss25KGRC side-by-side refrigerator/freezer keep falling down. It seems as though the shelves shrunk and no longer fit. Could it be that the freezer walls have gotten farther...
I had the same problem with my 3 year old GE Adora side by side. Call GE at 1800-386-1215. They were very helpful! They sent me all new shelves and drawers that were obviously wider because they fit perfect(only took a couple days)! Included in the shipment were spacers that I could of put on the ends just in case I needed more width. GE knows about the issue and is dealing with it on a case by case basis.
May 21, 2010 | Refrigerators
Broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Feb 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
Hi i have a Daewoo Lanos R Reg 1600. It keeps drianing the batte
I have replace the ignition switch itself in Hondas that had starting problems. The switches were worn out.My idea is maybe they use a simular switch. Unfortunatly I think the last one I bought was like $55.00 retail. If you do a ignition switch make sure you disconnect the battery first.
I hope this info helps.
Sep 27, 2009 | 1999 Daewoo Lanos
Some times water flowing from bottom side of the fridge
There should be a drain pan directly below the icebox which needs to be emptied from time to time. Some units have a drainpipe connected at the back, if yours has one, it may have become blocked.
Mar 13, 2009 | Daewoo FR-064R Refrigerator With Ice Box
Refrigerators Logo
118 people viewed this question
Top Daewoo Refrigerators Experts
John Tripp
John Tripp
Jerry Greenberg
Jerry Greenberg
noel
noel
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
