Question about Maytag Dishwashers
The power is on the machine but when the start button is pushed the light does not come on and none of the cycle will start.
  • 11,896 Answers
Most common cause is a faulty door switch that will not let the machine operate. There is also a thermal fuse in the back beehind the rear panel that can blow and allow some power but not enough to operate the machine.
Posted on Oct 11, 2010
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Whats wrong i push the power everything good, light on.when i push the start the light , is off
Depending on the washing machine there is a time delay between when the "Start button" is depressed and the actual start of the cycle, also the lid, on a lot of newer washers, must be closed to start the cycle. Give it 30 seconds to start, if it does not start, post again.
Dec 17, 2014 | Washing Machines
I have a Fisher Paykel clothes Washer Model WL42T26KW1. It has quit agitating. It spins, and rinses, but does not agitate. None of the lights are blinking and it is not giving any warning beeps. Can y
Push power button and start button together, push water level up than push start button, turn machine off at wall and unplug it, plug back in and start machine as usual, that may fix the problem, if not, suspect the ECU board is faulty
Nov 22, 2014 | Fisher Washing Machines
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 | LG WM2016C
Model 7305 - power light comes on when switch is pushed but none of the cycle lights or Start button come on when buttons are pushed
Problem was solved by pushing the very hard to find black reset button in the center of the back of the dryer.
Feb 22, 2010 | Asko Dryers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Dishwashers Logo
75 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
