Question about Watches
I bought a watch through ebay and it does not work. The indicators are losing in perostrofi and the day does not work.
  • 5,568 Answers
If the watch was described as 'working' or new, you may be able to recover your cost through eBay if the seller is not cooperating. Check their website for instructions on filing a claim if you are unable to contact the seller.
Posted on Oct 11, 2010
Tag Heuer watch losing time
Make sure the voltage on the new battery is correct. Just because a battery is new does not mean it is good. That is likely the problem.
Apr 21, 2012 | Tag Heuer 2000 Classic WK1320.BB0316 Wrist...
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Mar 08, 2011 | Jacques Lemans Classic Automatic...
My watch has been losing time all day long. It runs at least two to five minutes slow in the course. I bought it in 2006.
Overhaul is needed for your watch. It has mechanism, and it needs to be serviced every 4-5 years. Just imagine what would your car do without service! So, go and see the watchmaker.
Mar 01, 2011 | Longines Evidenza L2.671.4.78.9 Watch for...
Need help adjusting the day to english
Usually pulling out the crown to the second position sets the time by turning in one direction and the day by turning it in the other direction. I some you will need to advance the time through 24 hour cycles till you get the proper day displayed and then set the date.
Jun 19, 2010 | Watches
Watch stops or loses time every time i wear it.
normally automatic watch need to wear at least 8hrs in a day ,then it works for next 30hrs.if it stops or loosing time, it indicates that needs service with lubrication .
Feb 23, 2010 | Navy Seal Luminox Dive Watch
Analog hands lose time when worn.
This is usually a indication that the minute hand is slightly loose on its pinion. This requires that the hand be tightened, so that it does not slip. Best left to a watchmaker.
Nov 23, 2009 | Casio AMW320R 1EV Casual Sports Watch
Hello. I just bought an Oris Williams automatic watch on EBay. I was able to get it started and adjust the day/date but it stopped overnight and now it will not re-start. I tried moving the watch around...
I presume they told you on E-Bay that the watch ran ok. If it was mis-representitive that's another story that you probably have some recourse through E-Bay to return and get you money back. If you are stuck with the watch, then it may just need a good cleaning by a reputible watch maker/repairperson. You can also purchase some rather inexpensive watch winding machines to keep the watch wound if you don't wear it all the time. Hope you get it working, Good Luck
Nov 17, 2009 | ORIS Watch Williams F1 Team Day Date...
New watch is losing 5 to 15 minutes a day
This could be that the battery is slow. Newer swiss watches have a indicator in the movement of the watch that makes the sweep second hand skip every few seconds to indicate that the battery is slow. On regular japan made watches the watch just simply starts slowing down. Your watch could be new but the battery in it could have a long shelf life.
May 11, 2009 | Kenneth Cole KC1104 Wrist Watch
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Rolex watch
if your watc is automatic or self winding,you need to use your watch at least 12hours a day,to set the time , wind the crown counter clock wise,until the crown lose then full the crown to set the time,after setting the time fush the crown then wind it clockwise to lock again! thank you !
Aug 26, 2008 | Bulova Watch
Watches Logo
32 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
