Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Water not entirerly draining, e04 code continues on...
I have cleaned and checked drain hose....ok...i have open the drain on the lower right part of the front of the machine and have drained water from it...code conintues....do i need further things to do... i am at a loss since i cannot get anyone out to fix it. thanks We have a Nexxt 500Series Washer (WFMC3301UC) that kept getting the E04 error. We took our machine apart and found no blockages. We've also used 3 affresh tablets to flush out residue, stopped using anyother other than HE powder & reduced the amt we had been using. The machine still comes to E04 on a warm cycle but doesn't seem to happen on hot or quick wash. Its just 1 year over the warranty and is getting really frustrating! Any other ideas? Thank you!
Http://applianceguru.com/forum2/14805.html
Wow - I can't believe it. I had the SAME problem and searched the internet. This was the first site I found and was initially discouraged since there was NO solution, but upon further searching, I found the answer. I'll post the site here http://applianceguru.com/forum2/14805.html and you can just hop on and find out the answer in a much more helpfully worded way than I could ever do it!
I found a girls bobby pin and a rubber band stopping my drain from functioning! I thought it would FOR SURE be legos, but those boys are off the hook!
Posted on Oct 14, 2008
Wfw9150ww00
Make sure your washing machine is on level ground, if the machine is off balance it will stop.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
What does the E04 error code mean?
E04 means that you are not draining quick enough, if you are using HE detergant then your drain line is probably clogged. There is a round access panel on the lower right corner of your washer. If you stick a small screwdriver through the tiny little hole on this panel and twist the panel off you will see the drain pump catch. You can twist this cap off by hand and remove all the debris inside. WATCH OUT a lot of water will be coming through.
Dec 07, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch nexxt 500. E04 message, checked drain area (round circle at bottom, checked ball valve, checked drain hoses, checked and cleaned container at the top right back of machine-where exterior discharge...
This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 01, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Lg washer not draining
On a front loading LG there is an acess panel on the lower left of the front panel. Open that little door and use the small hose to drain out the water left in the machine. (as long as the hose is not plugged with sand) Now, unscrew the big thing next to the hose, which is a filter. Chances are there is something there blocking the flow of water to the pump. If it is clear and still no pump out, you will have to replace the pump motor. (possible impeller loose on motor shaft)
Nov 11, 2009 | Washing Machines
I have Bosch Nexxt 500 Washer. It stops draining and flashes E04 error. Any idea what is causing it or how to troubleshoot and repair?
The error indicates that the machine has taken too long to drain the water. Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
  3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 20, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water Does Not Drain
You may need to Clean out the pump catch to do this you need to remove the drain pump access cover, insert a pointed object (or tool) into the hole, Bottom right front of the unit push in to release the latch and rotate the cover clockwise.
you will need to clean this out use a shop vac to remove the water in the unit or have plenty towels handy
AS far as the fault code
E:04=Er:04washing=Door control broken
Cause=Faulty Triac or control module
Feb 17, 2008 | Siemens WFXD5200UC Front Load Washer
Aftron Washing Machine draining power
check and see that the entire drain line is free from any obstructions, if you have lowered the hose and still not draining entirely, its a sure sign of obstruction somewhere in the drain line or even the drain pump.
Jan 27, 2008 | Washing Machines
you did not say what make ,but anyway,there is probably a obsuction in the bottom hose on drum, ie sock, underware remove it and see.. close ire
Nov 27, 2007 | Bosch WFMC 3200 Front Load Washer
E04 not draining
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Nov 20, 2007 | Bosch Exxcel WFO 2264 Front Load Washer
E04
Perhaps try opening the round panel on the front of the machine at the bottom and cleaning that hose...good luck because it might be messy.
Nov 19, 2006 | Bosch WFMC 2100 Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
643 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
