Question about Hanns.G Corporation HU-196DP LCD Monitor
My Hanns-G LCD 1080P will not stay on more than a minute or two and everything is connected and the power light is still lit. It just started this 2 weeks ago and the monitor is only18 months old. Any idea! Richard
  • 734 Answers
Hi Richard,
This may only end up as one step in several of trobleshooting, but it's worth it for you to take this approach. Disconnect the monit(or and take it to a neaby friend's house (wo serves good cocktails) and connect the monitor to his/her conputer. Ids the same symptons present themselves in in a few minutes, you've unquestionably narrowed the problem to the monitor, and it means it has elements inside that have worn to the degree that a new monitor is advisable.
If your monitor performs just fine and at some appreciable length of time that this seems the inescaple conclusion, you immediately know that your computer is heating up at the video/processor area and shutting off all video presentation in order to reduce heat and save the mainboard/motherboard from a meltdown of the tiny circuits in that area using the inbuilt heat sensor and auro-shutdown feature it contains.
I apologize for your issue not being addressed sooner. The techs here realized that there's no instant gratification in a "solution" like I've written, so they moved on.
Therefore, please refrain from giving me 2 thumbs up while you go and carefully get this figured out. 2 thumbs reduces my rating percentage for telling you the exact way to find out about your problem for free. I prefer you leave no feedback until you do so.
Kind Regards,
TeSelkie
Posted on Oct 11, 2010
Display went dark/black- symptoms point to T-con board but after 20 minutes, display lit up for 2 minutes then went dark again. Same thing happened again after next 20. After 60, display stayed on
I was a Samsung tech for 3 years, and T-cons are a common problem. But it sounds like a loose wire to the T-con, I have came across the same issue in the field. I would break it apart and look for a loose connection.
Thanks,
Jason
Jun 24, 2016 | Samsung UN39FH5000FXZA - 39in 1080p 240...
Hannspree HF289H Black screen SIngle orange light once and completely unresponsive
There is two chance for theis problem. 1) there is missing voltage to the back light inverter boadr or 2) the back light inverer is faulty. Check the power supply volatge to the back light inverter board. Normally its 24v for all lcd back light inverters. If the power supply is ok then you have to replace the back light inverter board.
You can check is there is any picture on the lcd screen by the help of a tourch . light the tourch near to the lcd screen and wach the screen from different angel while the PC is in ON position.. in some angle you can see the shadow of picture if every thing else working fine except back light.
If so there is powersupply missing or back light iverter is faulty. You have to replace the back light inverter board with a new on because there is no repair possible with the board. Also the spares will very difficut to get.
Ajin
Apr 01, 2012 | Hannspree HF289HJB 27.5 in. LCD TV
I have a few issues with an old probably dinosaur Coleman Presidential III 7995a-856 Heating unit. I've had 3 different repairmen look at it and they're clueless. The main pilot will light and stay lit...
if the pilot is clean and and strong then this should play on to the thermocouple , i take it you have changed the thermocouple , and the connection is good at the gas valve , then if this going out could be 1, powerunit on gas valve not holding at thermocouple connection
2. Hole in heatexchanger blowing out pilot when blower comes on
I take it the pilot stays on untill fan comes on and keeps going out , I would think about not putting any more money in to this and get new if sounds as the heater has had its day ,
Dec 17, 2010 | Coleman Heating & Cooling
I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
My Hanns-G LCD monitor goes black with the word "ADJUSTING" every 2 minutes or so. Whats wrong with it? How do i fix it?
this probably the auto key stucked, or defective. Use a small tool to release key with extreme care.
Jan 15, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
My Hanns-g HC194D doesn't display anything - just clicks when power on. Using VGA (blue) connection to KVM.
This monitor is 2 1/2 weeks off warranty. With nothing to lose, I called Hanns-G and they provided a courtesy extension of my warranty. As you suggested, they believe it is probably either a circuit or the power supply. I pay shipping to them, they repair and ship back. Only thing not covered would be LCD screen (1 yr warranty anyway so not expected). I am very pleased with their responsiveness - only need to supply proof of purchase (which I scanned onto system when I bought).
Thanks to louie12fix for an very helpful reply.
Oct 02, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
PS3 or LCD TV?
when the ps3 is in standby hold down the power button for over 4 seconds, it runs the optimal screen settings page. hope this helps
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Hanns.G Corporation HU-196DP LCD Monitor Logo
173 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
