Question about Gateway MX3215 Notebook
Powers up no video on screen or external monitor seems laptop has endured a strike to the keyboard area, noticed it when i removed it to check for loose connections.
  • trig55 Jun 01, 2008
    It seems the power up is a fake, i do get the power led but no response from the num lock or fn key combos. Tried a stick of 1 gig mem that i know is a good stick from another comp i have.
    NO luck.
    The cpu works fine i tested it in a dell my friend had.
    i even ripped th whole thing into peices to try to find a burnt or cracked chip no luck on that either.
    any other info that anyone can provide would be great thanks so far. I know its a checklist kinda thing that has to be done to find the problem and my fear is itts the main board does anyone have one for sale? cant find any on ebay.
  • 41 Answers
Ok i have this laptop and this has happend a cupple times all i did was go in and check the video cables they were loose
Posted on Aug 06, 2008
Get a new motherboard. umm wait i did lol (:
Posted on Jul 02, 2008
    Scholar:
  • 139 Answers
U must be be sure yr system is up n working most times u power it u see the green led that one is bcos its on a power source. now couple yr system back the way it was. power it on make sure the green led is on, then press the caps lock or the fn + num lock key on yr keyborad n see if the caps lock led n num lock led will come up. if it doesnt come up then yr system wont display even with a CRT. now remove yr ram(memory) then replace it back n be sure its seated firmly again power yr system up if it doesnt come up try using a diff ram thats working well n test yr system again. if still not on then try replacing the processor. next tell me what happend so i know.
thank u
hope this helps
Posted on May 31, 2008
Vertical lines on my compaq cq61
Problem is;
1) Bad graphics chipset,
or
2) Bad Video Cable, or loose connections,
or,
3) Bad screen Inverter,
or,
4) Bad LCD screen.
A) Graphics chipset:
(Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The chipset, or I.C. used for graphics; is the graphics chipset.
More properly known as the G.P.U.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU )
Laptop OFF, monitor OFF, connect a VGA monitor; to the VGA connector on the laptop. (Port)
(Left side of laptop, if memory serves)
This is a General example of a VGA connector, (Port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
You have at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
(The F4 key is the Display Toggle-Over key)
Still no?
Hold the Fn key down again, and tap once more on the F4 key.
Same display on external VGA monitor (Red lines), suggests problem with the graphics chipset.
Good display on external VGA monitor means;
Problem with;
1) Video Cable
2) screen Inverter
3) LCD screen
http://tim.id.au/laptops/hp/hp%20g60%20compaq%20presario%20cq60.pdf
If you find it is one of the three stated above, post back in a Comment; and I'll guide you step by step, in diagnosing.
Will require partial disassembly of laptop, but not very far.
Will also require an ESD wrist strap.
Average cost is around $3 to $6.
Example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Needed to keep from Static shocking, the delicate hardware components inside the laptop.
[All power removed;
Loosen Keyboard, and roll over out of the way. Do NOT disconnect Keyboard Cable.
Remove Keyboard Cover.
Remove Display Bezel.
Remove screws that hold LCD screen to Display Cover, and check Video Cable connections to back of LCD screen.
The plastic frame in front of the LCD screen, is the Display Bezel.
Laptop closed the top cover is the Display Cover.
Just basic instructions. Like I said, I will step by step you through it, if you wish ]
[Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL (or more than one), or a series of LED's.
(Light Emitting Diode)
The Compaq Presario CQ61 series of Notebook PC's, uses a single (1) CCFL.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital letter -> O <-
Average length is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
The screen Inverter converts the power (Electricity), from the laptop; for the LCD screen, and Backlight.
Backlighting that uses CCFL, uses a screen Inverter.
Backlighting that uses a series of LED's, May or May Not use a screen Inverter.
It seems when the LED technology first came out, they did.
Later designs do not seem to.
Regards,
joecoolvette
Mar 25, 2013 | Computers & Internet
The 450sx4 screen is bright but no video
Many computer users spend long hours online every day and don\'t realize that looking at a bright laptop screen can be hard on the eyes. If you spend a lot of time in front of a laptop screen, consider reducing the brightness of the screen at the earliest opportunity. There\'s a quick and easy way to perform this task so you can save your eyes as well as your battery power.
Press and hold the "Fn" key on the laptop keyboard. This key is usually located at the top right or bottom left of the keyboard. Press the "Up Arrow" and "Down Arrow" keys, which are usually located in the lower right of the keyboard, to increase or reduce the brightness of your laptop screen. Adjust the level so that you can gaze comfortably at the screen without any glare. Disconnect the battery charger from your laptop and repeat the above procedure. On some laptops, the screen brightness varies considerably, depending on whether or not the device is charged. Hope this helps.
Jan 22, 2013 | Gateway 450SX4 Notebook
Fix my broken acer aspire 9805wkhi display
Horizontal lines going down the screen, generally indicate a problem with the Video Cable, or screen Inverter.
The Acer Aspire uses a screen Inverter, because the Backlight is a CCFL. (One)
Primer before I go on;
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
As stated previously; the Aspire 9805wkhi Notebook PC, uses a single CCFL for a Backlight.
http://www.screentekinc.com/Acer_Aspire_9800_Series_9805WKHi--20.1-inch--1680x1050-wsxgaplus-laptop-lcd-screen.shtml
http://www.laptop-power.co.uk/laptop-screens/acer/aspire/series-9800/model-9805wkhi.html
http://www.screenaid.com/acer-aspire-9805wkhi-laptop-lcd-screen-17-wxga-glossy-ccfl-backlight-p-8646.html
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Basic example of a CCFL,
View the last 8 photos.
A screen Inverter is used to convert the power (Electricity), from the laptop; for the LCD screen, and Backlight.
Note* Laptops that use a series of LED's for a Backlight, do not use a screen Inverter.
Primer over.
A) An external display device, such as a VGA monitor for example; should be connected to the laptop ->First; to make sure the graphics chipset is OK.
I believe it is OK, but this is a diagnostic flowchart, and the graphics chipset HAS to be eliminated as the problem; Before going on.
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
The VGA port is right in the middle, on the back of the laptop. Here is an example of a VGA port,
(Scroll down for example of VGA Cable)
With this laptop you can also plug a DVI connector, from a flat LCD screen monitor (Usual connector for digital flat screen), and use it instead. It's the white(?) port right next to the VGA port. (Closer to Left side, than VGA port)
Example of a DVI port, and DVI cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Turn the laptop on.
There are at least 3 display options;
2) Internal monitor of laptop AND external display device
3) External display device ONLY
Press the Fn key, hold it down; and tap once on the F5 key.
(The F5 key is the Display Toggle-Over key)
Still no graphics on external display device?
Hold the Fn key down again, and tap once more on the F5 key.
Good graphics on external monitor = Go on.
Bad graphics on external monitor = Problem with the mounting of the graphics chipset; to motherboard. Or bad graphics chipset. (Not very common)
B) Video Cable:
The Video Cable connects to the motherboard, up under the Keyboard. (And Top Cover's metal Static Shield) From there it routes up under the left Hinge, and up into the Display Assembly.
The main part of the Video Cable, then connects to the back of the LCD screen. There is also a separate cable coming from the Video Cable, that connects to one side of the screen Inverter.
The thin plastic 'frame' in front of the LCD screen, is the Display Bezel.
The screen Inverter is a small long circuit board; located behind the Display Bezel, and mounted down towards the bottom of the Screen Frame.
Basic example,
http://www.amazon.com/Inverter-Aspire-6930G-8920G-8930G/dp/B005GCD446
{The LCD screen is an assembly. It is composed of layers held in a specific pattern, by the Screen Frame. A thin metal 'picture frame', if you will.
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor icon }
Due to just normal repeated opening, and closing of the laptop; the Video Cable can become pinched, then pulled on.
This can lead to a loose connection at the motherboard side; and/or back of LCD screen. (Also check screen Inverter connection)
Can also cause damage to the tiny wires inside the Video Cable.
(Stretched/Broken)
If there is obvious signs of damage to the sheath of the Video cable, there may be damage to the tiny wires inside.
To add; with age the insulation of the tiny wires inside the Video Cable, can deteriorate.
This can lead to exposed wires inside the sheath of the Video Cable, and lead to their touching each other.
It is best to perform a continuity check, with a multimeter set to OHM's. (1K)
Check each wire. Also have an assistant gently wiggle the Video Cable, as you check it. (Fluctuation of reading of multimeter, indicates a broken wire)
If you do not have access to a multimeter, perhaps take the cable down to the nearest small computer repair shop; and see if they will run a continuity test for you. (Few bucks)
The Video Cable's condition, and connections; HAVE to be checked before going on.
You MUST rule the Video Cable out as the problem.
Problem here is there is no Service Manual; nor guides in how to disassemble, that I have found; nor has one come into the shop.
(Made in what? 2006? Hmmm?)
Looking at the reviews of it, to see what it looks like; the laptop looks to be the type of model that the Keyboard is removed, then the Top Cover (Upper Case); THEN access to the motherboard side of the Video Cable, can be gained.
Fun stuff, huh?
ALL power is removed. Remove the AC adapter (Charger), and Battery.
Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
Basically follow what this gentleman is doing. Screw locations may not be the same for the inside area on the bottom; but will have screws that go around the perimeter of the Base Enclosure.
(Bottom Cover)
http://www.youtube.com/watch?v=6k-FnZze3c0
Also on yours, look down in the Battery Compartment for screws to remove, and when the DVD drive is removed, see if any screws are along the 'lip'. The outside edge of the laptop; where the outside edge of the DVD drive was.
(Going from bottom view towards the Top Cover, there may be screws in that 'lip')
Look along the compartment opening edges, too. (Along the lines of the one's he found )
Ram Memory compartment, etc.
The Keyboard has Tabs on the bottom edge. The edge that faces you, not LCD screen side.
http://www.amazon.com/Acer-Aspire-9805WKHI-Replacement-Keyboard/dp/B006T0V8VA
(Click on photo to enlarge)
When the Keyboard is removed, it is slightly tilted up on the LCD screen side; and then moved forward a little. (LCD screen side)
If you lift the Keyboard straight up, you may break the Keyboard tabs, and/or Top Cover.
The top of the Keyboard has Detents.
May be 3 to 4. (Maybe 5)
The Detents are small (Very) rectangular shaped, and right above the Keyboard. Once depressed with a flat tipped Jeweler's screwdriver, the Keyboard can be slightly lifted in that area. (LCD screen side)
Then go to the next one, and slightly lift the Keyboard, and so on.
The Keyboard Cable STAYS attached to the Keyboard. It has NO connector on the motherboard end. (No plug connector)
It is a Flat Flex Cable.
After all screws are removed, the Top Cover pops loose.
The Top Cover has Tabs, and the Base Enclosure (Bottom Cover), has matching Latches.
http://www.youtube.com/watch?v=3AxVE6__kEY
You have to PHYSICALLY check the motherboard connection side of the Video Cable, AND LCD screen side. Visual inspection will NOT do.
http://www.insidemylaptop.com/replace-screen-on-acer-aspire-5830tg-6782-laptop/
Look for screw covers going around the perimeter, of the Display Bezel. These are usually plastic, or synthetic rubber. I just gently pry up on one side of the cover, and then pry it up, and off.
The screw covers are attached with a type of rubber cement.
If carefully pried off, the screw cover, and it's glue may be reused.
[ Most of the time. I stick them (L-I-G-H-T-L-Y) to the Display Bezel, for safekeeping ]
Now remove the Philips head screws.
The Display Bezel is gently pried off, by flexing one side; and sliding your fingertips under it.
(On LCD screen side. I wear computer gloves. You may wish to cut a cereal box, or similar cardboard; to fit the inside edges of the Display Bezel; and protect the LCD screen from your fingernails )
Work along heading towards the Top, and around.
Once the Display Bezel has popped about halfway, or more off; the Display Bezel should come the rest of the way off all at once.
Remove the screws which hold the LCD screen to Display Cover.
Tilt the top of the LCD screen towards you; so you can access the Video Cable connection; to LCD screen.
Continuity check reveals the Video cable to be OK? Connections were tight?
Replace the screen Inverter.
Testing a screen Inverter = using a Sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Due to this; the low cost, and ease of access to replace; the screen Inverter is usually just replaced. Have to work with what you've got.
Screen Inverter replacement doesn't do the trick; replace the LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 20, 2012 | Acer Aspire 9805WKHi Notebook
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
XPS M1530 video issues
Check out the ribbon and other connectors that are powering/connected to your screen. It appears you may have an intermittent wiring situation.
Or the circuitry or keyboard switch that switches the video back and forth from screen to external output may be the culprit.
Mar 24, 2017 | Dell XPS M1530 Laptop
Keyboard lights up screen stays black....after inserting recovery disk screen still remains black...
Would like you to attach an external monitor for a diagnoses.
A VGA monitor.
Can be a CRT monitor that resembles a small TV, or a flat LCD screen monitor, that has a VGA cable attached,
http://en.wikipedia.org/wiki/VGA_connector
1) Laptop OFF, monitor OFF, attach the VGA cable of the monitor to the laptop's VGA connector.
[For the HP Pavilion dv6000z Notebook PC, the VGA connector is on the Left side at the Rear. Second port from the rear. 15 pins.
3 rows of 5]
2) Turn the monitor on. If a CRT style allow it to warm up.
3) Turn the laptop on.
By default the display should show on the external VGA monitor.
If not, press, and hold down on the FN key,
(Second key from the left, on the Bottom row on the Keyboard),
and tap on the F4 key.
(Top of Keyboard towards the left)
Still no? Hold the Fn key down again, and at the same time tap on the F4 key.
There are 3 display options;
IF, the display shows up on the external monitor, and if it is OK, the problem lies in the Display Assembly, and/or the Video Cable.
More on that in a moment.
IF, the display does Not show up on the external monitor, or if it is garbled, the graphics chipset is bad.
HOWEVER, there is a problem with the graphics chipset, for the dv6000 series of HP Pavilion Notebook PC's.
More specifically it isn't actually the graphics chipset itself, but the mounting of the graphics chipset to the motherboard.
More on this in a moment.
External VGA monitor shows a good display;
Video Cable:
The video cable is checked for apparent damage first, and at the same time, see if it's connectors are tightly plugged in.
On one end, the video cable is plugged into the motherboard.
(ALL power removed, AC adapter { Charger} and Battery, the Switch Cover is removed, and the Keyboard, far enough to lay it back out of the way. Keyboard Cable still attached to motherboard. The Display Cable is the one to the Far left, right under the left side of the LCD screen. The cable next to it, to the immediate right, is the Microphone Cable )
The video cable routed from the connection on the motherboard, up under the left Hinge Cover, and into the Display Assembly, where it then attaches to the Back of the LCD screen.
THIS connection must be checked also.
{ Just gave advice similar to this earlier. The asker's problem turned out to be a loose video cable connection, on the back of the LCD screen }
Examine the sheath of the video cable. See if there are signs of damage. If so the tiny wires inside the cable could be damaged.
Apparent damage or not, you may want to remove the video cable, and perform a continuity check with a multimeter. (Ohm's. Check each wire in the cable)
Video Cable connections prove to be tight, video cable continuity check proves video cable is OK, move on to the screen Inverter.
Primer:
A Backlight can be a CCFL, or a series of LED lights.
The Backlight is a CCFL for an HP Pavilion dv6000z Notebook PC.
[It is 2mm Wide, and 334mm Long. Or a little thicker than 1/16th inch Wide, and a little over 13 inches Long ]
A screen Inverter is used to convert power (Electricity) from the laptop, FOR the Backlight, and LCD screen.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Example of a screen Inverter for a Pavilion dv6000z Notebook PC,
http://www.nylaptopparts.com/index.php?main_page=product_info&products_id=560
The thin plastic frame that surrounds the LCD screen, and is in front of the LCD screen, (Resembles a picture frame), is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and at the bottom of the LCD screen area.
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
External VGA monitor does NOT show a good display, it is a graphics chipset mounting issue, more to follow.
Regards,
joecoolvette
Jan 15, 2012 | HP Pavilion dv6000z Notebook
Screen is blank. Computer is switched on.
This is probably due to a video card failure. It could also be a ribbon that connects to the motherboard for the LCD monitor. You can remove the keyboard and find the strip that connects the lcd screen to the motherboard. Not too much info but thats a start...
Jan 28, 2011 | Toshiba NB205-N210 Netbook
How do you switch between laptop screen to external monitors
You can switch to an external monitor by two methods.
1. Connect the external monitor to the laptop's video port, power up the external monitor first and the the laptop. The video information will automatically switch to the external monitor.
2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between external monitor only, both LCD screen plus external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :-
IBM ThinkPad = Fn + F7
HP and Compaq = Fn + F4
Toshiba = Fn + F5
Dell = Fn + F8
Feb 12, 2010 | Acer Computers & Internet
Vista 64 bit will not display on an external monitor
To solve this problem you should see on your keyboard a FN key by the windows key this key activates the secondary mode of your keyboard it has to be held down for this mode to stay on as soon as you let go of the keyboard returns to normal you should also noticed that F1-F12 have different symbol's on the keys one of them should transfers the display to you external monitor to get it to go back jut repeat the above steps hope this helps
Aug 02, 2009 | HP Compaq Evo Notebook N1000c
Gateway MX3215 Notebook Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
