Question about LG LHT854 Theater System
Only x2 of my speakers and sub is working for my lg ht503 digital receiver
  • 144 Answers
Do a speaker check if the speakers work change accoustic 5.1 settings until all speakers play if not swap speaker connections to see if speakers are faulty or channels on reciever is blown and replace accordingly
Posted on Oct 11, 2010
My speaker ports on the back of my lg dvd reciever ht503 aren't working the sub port and 2 more work but the remaining 3 ports ie front left front right and centre port arnt is it possible to fix I find...
Sounds like you have three blown power amps on unit. Sure it can be repaired if you are willing to pay the price. Probably cheaper to get new unit since most electronics nowadays are replaceable and not repairable.
Mar 09, 2014 | LG Audio Players & Recorders
How to replace the old faulty dvd drive in an lg ht503
This site has the parts in the UK. http://www.chsinteractive.co.uk/manufacturer_replacement_parts/lg/HT503TH/
Once you have the part you'll have to disassemble the receiver and replace the drive. Small phillips screw driver and patience.
Sep 10, 2013 | LG Televison & Video
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | Audio Players & Recorders
I need to make my LG DVD Receiver HT503 region free
I need step by step instructions how to set up my home cinema LG ht503
May 17, 2009 | LG LST-3510A DVD Player/Receiver
You should find the answer here.
http://www.dvd.reviewer.co.uk/info/multiregion/
May 17, 2009 | LG GSA-E10L (8801031212552) DVD±RW Dual...
Read no disc I only just it twice in 6 months
clean with lazer cleaning disc if not work must be faulty if so under 12 months old return to your retailer for a free replacment as lg dont repair
Mar 07, 2009 | HomeTech HT503 Main / Stereo Speaker
Home theater system protection kicks out
Nice write-up.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
On page 6 of the manual it states you should use a powered subwoofer and the unit provides a sub output on the rear panel for it. The message from the amp kicking out is that you're not going to get away with your workaround.
I would advise you to purchase a nice amplifier (2-channel bridgeable or single channel) for the subwoofer. That way you'd be sending only LFE signals and your receiver has provisions for adjusting its volume relative to the rest of the channels. I use a nice 5-channel Carver for my 3 subs and both Rear Surrounds.
On eBay I see what I would get if I were you - a Carver M-200T (120W x2; 300W bridged). I have one.
http://cgi.ebay.com/Carver-Magnetic-Field-Power-Amplifier-M-200t-120WPC-Amp_W0QQitemZ200327110781QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item200327110781&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
Mar 02, 2008 | Sherwood RD-6500 Receiver
I have a Pioneer VSX-35TX receiver when connected to the subwoofer there is no sound questions on what I am doing wrong.
Set front speakers for small and make sure sub is turned on in setup mode. If Front speakers are sent to large I believe the only time sub will work is with Dolby Digital Lfe signals. If sub is turned off of course it will never work.
Feb 10, 2008 | Audio Players & Recorders
HOmetech HT503 8 ohm speakers
WITHOUT ANY PROBLEM. THE SOUND WILL BE LITTLE SOFT BUT YOU CANNOT MAKE ANY PROBLE USING 8 OHM ON 3 OHMS AMPLIFIER
Nov 26, 2007 | HomeTech HT503 Main / Stereo Speaker
LG LHT854 Theater System Logo
396 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
